The dcd825 is supposed to play VCDs. I burned one with easyVCD (which has a great GUI) and it plays fine on the PC. On the dvd player the picture is fine, but the sound is funky. There is no sound except for every 7 to 8 seconds, a quick short burst of sound (aprox 1-2 seconds) plays.
I run the dvd player -Svideo into the TV and run the sound into my stereo. Oh one more thing, the remote does not have a mute button.
P.S (what's this firmware update people are talking about - can I really update my DVD player?)
"I drank what?" - Socrates
Sounds like the mpeg needs to be remuxed. Try the simple multiplex tool in tmpgenc with the vcd setting.
There is a firmware update for it available from phillips tech support. they mail you a cd that you play in the unit to update the firmware. -
Thanks for the reply. That was exatly the problem. I was trying to manualy set everything but then I went to the web site and read the section on converting the file for a VCD. it basically said - use the template ( which is what you just said) and it works ! Many disks gave their lives for this knowledge.
I would like to contact Philips for the upgrade but I spent each day for a week talking to them about the sound issue and trying to get the freakin manual from them. - do you have any advice for asking for the firmware. Are they willing? -
You can Download the firmware from
http://server33.hypermart.net/dvd-vcd/firmware.htm
It is in spanish (the site) but the upgrade is corect.
Burn it to a cd using iso9660 and mode2
turn on your dvd player, eject tray, put in cd, push tray closed and the upgrade will begin It takes a few minutes and it may turn the dvd player on and off. It will eject the disc when done. remove it and push the tray closed. your done.
Sound distortion when play CD on Magnavox ZV457MG9A
By AliceWonder in forum AudioReplies: 1Last Post: 12th May 2011, 12:16 -
Magnavox H2160MW9 with 160GB HDD - Virtual Clone of Philips 3575/76H
By wabjxo in forum DVD & Blu-ray RecordersReplies: 19Last Post: 26th Jan 2011, 18:34 -
Philips 3575/3576 and Magnavox H2160 Features, Setup and Operation
By wabjxo in forum DVD & Blu-ray RecordersReplies: 323Last Post: 10th Mar 2009, 15:55 -
Magnavox H2160MW9 with 160GB HDD - Virtual Clone of Philips 3576
By wabjxo in forum DVD & Blu-ray RecordersReplies: 4Last Post: 27th Sep 2008, 14:43 -
Magnavox H2160MW9 with 160GB HDD - Virtual Clone of Philips 3576H?
By wabjxo in forum DVD & Blu-ray RecordersReplies: 1Last Post: 12th Aug 2008, 13:01
