Hello,
My friends elderly dad has a problem with his Philips DVDR880 standalone recorder.
He left it recording a programme and didnt switch it off. This shouldnt normaly be a problem.
But he came back and not working.
The problem exactly is this;
the machine seems to have frozon / crashed.
the disc will not eject
the LED display says.. AEO1OSD this is not listed in the manual.
It will not respond to any button presses.
When I switch off the machine and turn it on, for a couple of seconds, the LED display shows these characters A638B6E there is a brief whirring inside as if the disc is trying to read, then it stops. and show the 1st LED image.
I think it may be the disc is just corrupted/ stuck
Anybody got any more informed ideas ?
thanks
Once you get the disc out...the problem will most likely NOT be solved either. Being a Philips 985 owner for over two years....I think I can safely tell you that the machine will need to go back for service.
Had the machine malfunctioned at power up and NOT during or directly after a recording....the newest Philips firmware MAY have cured the error message problem.
Most machines (Philips ones anyway) have a small slot under the front of the machine where you can manually eject the disc (or tray). I've read about it somewhere....never had the need to attempt it myself however.
I believe you can unplug the unit....then plug the unit back in again WHILE pressing the power button on the front of the machine to do a virgin restart....you will need to have the machine re-find all of the TV tuner stations....just like when you first purchased it. That may buy you enough time to eject the disc.
philips dvdr880 issues...
By colcol1 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 18th Jan 2012, 10:00 -
Philips DVDR 7260H Hard Disc Crash
By ikcdab in forum DVD & Blu-ray RecordersReplies: 3Last Post: 27th Apr 2010, 22:58 -
System Crash
By maximusbob in forum SVCD2DVD & VOB2MPGReplies: 22Last Post: 10th Dec 2007, 20:09 -
Philips DVP5982 resolution stuck on 480p ?
By nettroller in forum DVD & Blu-ray PlayersReplies: 1Last Post: 4th Aug 2007, 08:23 -
Pioneer DVR112d maybe faulty won't read dvdrs and makes system crash!!
By rockonvidtrade in forum DVD & Blu-ray WritersReplies: 12Last Post: 9th Jun 2007, 03:44
