Some xvid encoded files i downloaded wont open in tmpgenc or virtual dub. I assume it's not an encoding problem because out of the 9 files, 2 did work, and they were all encoded by the same person. V-dub has verfied that there are several bad frames in each file. I've tried div-fix but that doesn't find them. Does anybody know of a utility that can fix these frames or remove them altogether?
Results 1 to 9 of 9
No guarantee that it will work but give 'divxrepair' a try.
http://divxrepair.sourceforge.net/ -
Thanks for th link, bunyip.
I gave that a shot. Out of around 33000 frames in each file, it found around 32000 to be corrupt. It also turn out, that ALL of the files are bad, the only working parts, are extra credits added by someone else. So not I guess it IS an encoding problem. But the files do play without a hitch. What can I do without TMPENC and virtual-dub? -
Here's another one >
AviFixed 1.2:
http://www.web-zone.org/divx_dvd_tools.asp?data=24 -
use fourcc changer and change them to divx. Works for some xvids I have that caused problems
I tried this already, both with FOURCC changer and FFDSHOWs options Thanks Though.
Unistall FFDShow - Install Nics Xvid decoder >
http://nic.dnsalias.com/XviD-Dec.exe -
Ok I tried that just now. After installing nics codec, the video files wouldn't play properly, lots of crashes, weird artifacts etc.. I'm about to just give up.
repair xvid files
By greendesert in forum Software PlayingReplies: 5Last Post: 17th Dec 2011, 23:44 -
Tool to batch convert xvid to .mp4 for iPhone.
By Floob in forum Video ConversionReplies: 8Last Post: 14th Sep 2009, 13:20 -
Currently, what is the best tool to convert DVD/Xvid to iPhone format?
By mr_jbloggs in forum Video ConversionReplies: 3Last Post: 16th Aug 2008, 14:25 -
computer going nuts
By jyeh74 in forum Newbie / General discussionsReplies: 33Last Post: 11th Jul 2008, 21:18 -
Tool to scan and repair vob/ifos?
By milkydoo in forum Newbie / General discussionsReplies: 2Last Post: 20th May 2008, 18:21
