I have the spiderman dvd and i'm backing it up. I used vob blanker to blank out some of the special features and there is a section where there is the spiderman trailer.
I have a different spiderman trailer (quicktime) which i encoded to a mpeg2 (dvd) and renamed to .vob. In vobblanker there is an option for replacing the vob, so i clicked it and replaced it with this one.
The problem is when i load the completed dvd into dvdshrink, it comes up with an error. I'm guessing that u can't change the vob's without reauthoring the whole dvd???? Does anyone know how i can do replace a vob file with my own ??
lol, I lost my reply yesterday and didn't have time to post it again but here it is
I don't know how voblanker fully works but does it not replace the VOB and update the IFO's?. I would have thought it did
Menuedit and DVDRemake are 2 other programs I know that replace VOB's but they aint free
the longer free way is to use Ifoedit by splitting the VTS into individual cell ID's and isolating that cell containing the trialer. Replace the cell but you must also use Vobedit to check the original VOB/CELL ID and change the VOB/CELL ID of the new trailer to the same values. Join all the cells back up again (Filemerger comes in handy) and then run through Ifoedit to update the IFO's and VOB sectors
with any method you use, you must also ensure that the audio/subs stream formats & mapping match the titleset you are putting the cell into or else you will get an error. Maybe this is what is causing DVDShrink to barf in the first place. If it is then you may be able to fix it by changing the stream code using Vobedit to something that matches the original
Replacing VOB files : Need urgent help with chapter menus !
By Ash512 in forum MacReplies: 1Last Post: 12th Mar 2009, 04:26 -
Replacing audio in MKV file without re-encoding?
By 3560freak in forum Video ConversionReplies: 4Last Post: 2nd Mar 2009, 22:23 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 19:10 -
VOB to DV last VOB file finishes in about one second w/no data
By Gizmology in forum Newbie / General discussionsReplies: 3Last Post: 31st Jan 2008, 17:39 -
VOB DTS file to VOB AC3
By shanthaprasad in forum AudioReplies: 4Last Post: 25th Sep 2007, 13:34
