Anyone recommend a program for burning my dvd that i converted from an svcd with tmpgenc? i burned the file with nero but it didnt work...any suggestions?
I burn using RecordNow DX , it came with my DVD Burner and has worked well for me.
I also use DVDDecrypter to burn with.
I use Nero to burn CD's and data backups to DVD -
In what way did it NOT work. Be more specific.
A - Failed burn.
B - Not playable in standalone DVD player.?
A - try a different disk , slower burn speed
B - did you even author the disk ?
do i have to author it? sorry if thats dumb...can you recommend a good authoring program?
You can try DVD Architect 2.0, one of the best applc of its kind. It now supports subtitles and it is a real pro. You can do a hell with DVDA 2.0. Search around here for tools and DVD Architect 2.0. You can download a trial version.
Try Ulead DVD Movie Factory... well written and does a good job on menus and chapters.
Hello,
Hey dvd-ripper, do you work for ULEAD?? It seems like that's the only authoring program you recommend. Don't get me wrong, it's a great program (I use it frequently). It's just that others like tmpgenc dvd author work equally well. Just curious
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Burning Data Program on DL discs?
By PowerFalcon in forum MediaReplies: 2Last Post: 27th Jul 2011, 08:58 -
Program for simple editing and burning
By hodocka in forum Newbie / General discussionsReplies: 7Last Post: 24th Jan 2011, 23:16 -
VIDEO TS Burning Program
By videocheez in forum Authoring (DVD)Replies: 2Last Post: 30th Jun 2009, 06:55 -
Burning program options
By efiste2 in forum DVD RippingReplies: 4Last Post: 14th Jul 2008, 19:44 -
Whats the best DVD burning program out there?
By Tielurr in forum Newbie / General discussionsReplies: 5Last Post: 27th May 2007, 19:21
