Hello. I have searched the forums but have not found a fix for the following. I have been converting vhs videos to cd/dvd and because I am a total newbie experimenting with different programs. The one I liked for burning was Nero 6 which I bought. However now I have the full suite, I have found a problem that I cannot overcome. When I capture the video, using Nero VE2 I have no audio. It will not capture or play back, I have the icon clicked that says "enable capture device audio playback" but all I get is a thumping noise through the speakers. I have checked all the settings and everything appears to be correct. But no audio.
However I captured a video using Ulead Movie Maker (trial) and and another using Windows Movie Maker had no problems playing it back in NeroExpress and burning a disk. What I would really like is to be able to removed the Ulead and just use Nero.
I thought there may be a conflict between the sound card and the program, but I have no problems with play back, only capture.
I wrote to Nero help line, whose only suggestion was to uninstall reinstall. Which I have done. But no fix.
I have also on another group found someone who is experiancing the same problem with no fix advice either.
Can anyone here assist me in this problem
AMD Athlon 2500 +
WinXP Home
WinFast 2000 XP PVR
Sound Max Digital Audio
Flashfire.
Results 1 to 1 of 1
audio capture problem
By hudsonf in forum ComputerReplies: 7Last Post: 19th Apr 2008, 21:19 -
Archos 604 - Nero AVC audio problem
By sungpark71 in forum Portable VideoReplies: 7Last Post: 19th Dec 2007, 07:49 -
Help with audio problem in playing AVCHD files with Nero 8
By Ollie6431 in forum Newbie / General discussionsReplies: 7Last Post: 16th Oct 2007, 12:02 -
Nero 6 audio playback problem
By Rad17 in forum Newbie / General discussionsReplies: 2Last Post: 25th Aug 2007, 08:35 -
I Can't get Nero VisionExpress to see dvd files
By Quip in forum Newbie / General discussionsReplies: 5Last Post: 26th Jun 2007, 23:37
