Ok, I have a 2Wire PCMCIA wireless Card for my laptop that I was using with my 2Wire DSL Box for SBC DSL. But I'm confused about how to set it up to work at my office with our LinkSys Broadband Router. We have a network here so should I use some type of network settings to get it to work? Also how would I get it to work with another Wireless Router/Hub.
Thanks in advance for any help guys,
Venom
P.S. I tried just turning on my laptop here at work and my card nor my PC detected anything.
Is the Linksys at work a wireless router? If not, your wireless card in your laptop cannot connect to it. Other wireless routers can broadcast a SSID, or basically, a name for the wireless network that your card would be able to detect. Then, if allowed, you could connect to it.
If the router is not broadcasting an SSID you won't detect it, unless you're already using the same SSID. Have you spoken to your admin about hooking up wireless? They probably have all the info you need.
Nothing can stop me now, 'cause I don't care anymore. -
No I haven't, he's NEVER here (lol). What is a SSID and what would I need to do when going to my friend's house who has wireless. What settings do I need, etc...
Thanks so far guys -
SSID is basically the wireless network name. If it's being broadcast by the router you'll see it and you can connect to it. If it's not, you at least need to know what it is so you can set up a profile using that SSID. Otherwise you won't be able to connect.
I tried connecting to my friends Wireless at his home last night and I had no luck....could someone please tell me what settings I need to change or what it is that I am doing wrong.
Going wireless- what do I need?
By aelfheah in forum ComputerReplies: 11Last Post: 24th Nov 2011, 15:27 -
Wireless???
By rico1 in forum Video Streaming DownloadingReplies: 7Last Post: 4th Sep 2010, 17:40 -
Best Wireless Utility that can be used with any wireless card
By mol3000 in forum ComputerReplies: 4Last Post: 7th Jul 2009, 12:29 -
how to limit speed of users on wireless network (router-lan-wireless)
By deejay.2001 in forum ComputerReplies: 5Last Post: 2nd Nov 2007, 23:56 -
USB Wireless lan stronger than Internal wireless?
By Super Warrior in forum ComputerReplies: 11Last Post: 6th Aug 2007, 23:26
