When ever i try to convert my files it runs and when it gets to the part of trimming down the file it gets out of sync. The MPG itself is fine cause i can play it and have no issues with being sync. My log is listed please any help would be appreciated.
Starting SVCD2DVD: v1.51.2.0
Begin time: 8:08:26 PM
******** Ripping SVCD images to get mpegs (VcdXRip)
Analysing File: D:\test\1_FIXED.mpg
++ WARN: packet length beyond buffer (pos = 20 + size = 2304 > buflen = 452) -- stream may be truncated or packet length > 2324 bytes!
++ WARN: bad packet at packet #451 (stream byte offset 1048124) -- remaining 452 bytes of stream will be ignored
-->Processing 1 mpeg files
############### New MPEG File ###############
Type: SVCD
Horizontal Res: 480
Standard: PAL
Audio SampleRate: 44100
******** Demultipexing original mpg file
(Total size: 794MB, Duration: 00:06:45, Rate(MB/Min): 117.60)
******** Resampling audio from 44.1 KHz to 48 KHz
(Total size: 68MB, Duration: 00:01:52, Rate(MB/Min): 36.32)
******** Trimming start of video ES
- Trimmed 2081 bytes.
******** Multipexing elementry streams
(Total size: 774MB, Duration: 00:04:43, Rate(MB/Min): 163.82)
Analysing File: D:\test\1_FIXED_DVD.mpg
INFO: [???] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
INFO: [???] File D:\test\1_FIXED_DVD.mpv looks like an MPEG Video stream.
INFO: [???] File D:\test\1_FIXED_DVD.mpa looks like an MPEG Audio stream.
INFO: [???] Video stream 0: profile 8 selected - ignoring non-standard options!
INFO: [???] Found 1 audio streams and 1 video streams
INFO: [???] Selecting dvdauthor DVD output profile
INFO: [???] Multiplexing video program stream!
INFO: [???] Scanning for header info: Video stream e0 (D:\test\1_FIXED_DVD.mpv)
INFO: [???] VIDEO STREAM: e0
INFO: [???] Frame width : 480
INFO: [???] Frame height : 576
INFO: [???] Aspect ratio : 4:3 display
INFO: [???] Picture rate : 25.000 frames/sec
INFO: [???] Bit rate : 2521200 bits/sec
INFO: [???] Vbv buffer size : 131072 bytes
INFO: [???] CSPF : 0
INFO: [???] Scanning for header info: Audio stream c0 (D:\test\1_FIXED_DVD.mpa)
INFO: [???] MPEG AUDIO STREAM: c0
INFO: [???] Audio version : 1.0
INFO: [???] Layer : 2
INFO: [???] CRC checksums : no
INFO: [???] Bit rate : 16384 bytes/sec (128 kbit/sec)
INFO: [???] Frequency : 48000 Hz
INFO: [???] Mode : 0 stereo
INFO: [???] Mode extension : 0
INFO: [???] Copyright bit : 0 no copyright
INFO: [???] Original/Copy : 1 original
INFO: [???] Emphasis : 0 none
INFO: [???] SYSTEMS/PROGRAM stream:
INFO: [???] rough-guess multiplexed stream data rate : 2693296
INFO: [???] target data-rate specified : 10080000
INFO: [???] Setting specified specified data rate: 10080000
INFO: [???] Run-in Sectors = 89 Video delay = 13019 Audio delay = 0
INFO: [???] New sequence commences...
INFO: [???] Video e0: buf= 237568 frame=000000 sector=00000000
INFO: [???] Audio c0: buf= 4096 frame=000000 sector=00000000
INFO: [???] STREAM e0 completed @ frame 64294.
++ WARN: [???] Discarding incomplete final frame MPEG audio stream c0!
INFO: [???] STREAM c0 completed @ frame 107163.
INFO: [???] Multiplex completion at SCR=231476662.
INFO: [???] Video e0: buf= 237568 frame=064294 sector=00372556
INFO: [???] Audio c0: buf= 640 frame=107163 sector=00020372
INFO: [???] VIDEO_STATISTICS: e0
INFO: [???] Video Stream length: 750759516 bytes
INFO: [???] Sequence headers: 3638
INFO: [???] Sequence ends : 0
INFO: [???] No. Pictures : 64295
INFO: [???] No. Groups : 3638
INFO: [???] No. I Frames : 3638 avg. size 37425 bytes
INFO: [???] No. P Frames : 17931 avg. size 19973 bytes
INFO: [???] No. B Frames : 42727 avg. size 6002 bytes
INFO: [???] Average bit-rate : 2335200 bits/sec
INFO: [???] Peak bit-rate : 3429200 bits/sec
INFO: [???] BUFFERING min 15 Buf max 134306
INFO: [???] AUDIO_STATISTICS: c0
INFO: [???] Audio stream length 41150980 bytes.
INFO: [???] Syncwords : 107165
INFO: [???] Frames : 107165 padded
INFO: [???] Frames : 0 unpadded
INFO: [???] BUFFERING min 15 Buf max 395
INFO: [???] MUX STATUS: no under-runs detected.
++ WARN: mpeg stream will be padded on the fly -- hope that's ok for you!
++ WARN: autopadding requires to insert additional 141036 zero bytes into MPEG stream (due to 511 unaligned packets of 512 total)
******** Creating DVD Folders...
Creating VTS #1
SVCD2DVD: DVDfolders
Generating DVD folders please wait....
-->: DVDFolders creating VTS
-->: VTS 01
STAT: Processing D:\test\1_FIXED_DVD.mpg...
!!!: GOP is not closed on cell boundary (may be non seamless)
-->: DVDFolders creating table of contents
scanning D:\test\VIDEO_TS/VTS_01_0.IFO
(Total size: 774MB, Duration: 00:05:00, Rate(MB/Min): 154.79)
============ Complete ============
============ Duration: 00:22:06
I have tried to use your post and this particular mpeg comes out muffled and the sound then is horrible. it is only for 2 and 3. i have three mpg files and the second and third i am having problems with.
I think this is a set of mpg which have known issues. (at least several people have the same issue with the same log file). It is the sources which are shafted. Nothing can be done.
I had probs with them too
run them through SVCD2DVD about 10 times after messing with mpegs,still no joy. This is the first one ive ever had not work so I Had to use ulead movie factory in the end. It worked But took so much longer & the resulting file was loads bigger
than when done through SVCD2DVD
Where to start? I'm a amateur photographer and I want to start out in video
By James Wright in forum Newbie / General discussionsReplies: 14Last Post: 3rd Jul 2015, 15:12 -
Trimming AVI in virtualdub,direct strem copy ignores my start and end point
By Rudyard in forum EditingReplies: 4Last Post: 4th Oct 2010, 20:11 -
Windows Movie Maker. Blank video when splitting, trimming video clips
By rlarden in forum EditingReplies: 2Last Post: 3rd Jul 2009, 07:23 -
Virtual VCR Trouble - Error 80070003: Cannot start graph
By MJDore in forum Capturing and VCRReplies: 2Last Post: 10th Mar 2009, 20:12 -
start up programs trouble
By romanstopme in forum ComputerReplies: 8Last Post: 2nd Nov 2008, 00:52
