I'm using DVDSanta to convert and burn my AVI file.
When I play the AVI file in my default player the sound and video are in sync with no problems, however once I convert it to a VOB file the sound gradually goes out of sync.
The AVI is using a DIVX codec and the resolution is 480x272... I am converting to 720x480 widescreen 16:9 NTSC. I've tryed numourous settings but it ALWAYS goes out of sync can anybody HELP!!
thanks in advance
Galvin
Results 1 to 14 of 14
Have you scanned your AVI for bad/undecodable frames?
/Mats -
there could be a few reasons for your problem. did you re-encode your audio to 48000. what is the original frame rate of your avi? are you encoding it to ntsc or ntsc film?
member since 1843 -
A video file that plays sync'd on a PC won't necessarily be sync'd on a set top. Too many hardware variables in the PC realm that don't exist in the set tops.
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
Is the source AVI PAL or NTSC?
/Mats -
yeh i was going to ask that,it may be PAL-25fps,that would do it.
ive had problems with PAL-NTSC going out of sync before. -
Originally Posted by Galvin
/Mats -
Originally Posted by mats.hogberg
No, it's the AVI that has to be scanned. If some frames are bad/undecodable, sync probs will arise (if it can be reencoded at all). Use VirtuaDub MP3 Freeze to scan the AVI.
/Mats -
Sorry. Let me rephrase my question.
I have captured in a TV show in mpg format and suspect some dropped frames. Will VirtualDub scan just AVI format? Can it scan mpg? Is there a utility that can perform the same function for mpg if VirtualDub doesn't work?
<runs off to look up VirtualDub guides> -
Originally Posted by spawnuvsatan
/Mats
Avi: fine, DVD: audio out of sync
By Sebastian2011 in forum Authoring (DVD)Replies: 2Last Post: 22nd Jan 2012, 13:32 -
Convert AVI to iDVD compatible file with burned-in subtitles?
By tictacjak in forum Video ConversionReplies: 0Last Post: 7th Sep 2011, 12:28 -
Decrypted DVD9 plays fine from harddrive, not when burned to DVD+R DL
By ndaher in forum DVD RippingReplies: 4Last Post: 7th Sep 2007, 14:35 -
converted vob files play on computer fine..skip when burned to dvd
By cduval04 in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2007, 18:26 -
AVI File Burned to DVD won't play ?
By DuBsTaR in forum Newbie / General discussionsReplies: 7Last Post: 24th May 2007, 20:20
