I have a demuxed MPEG-2 stream, which I would like to mux into one file.
Partial answers possible ....
1. Question.
When I use mplex, I use the option "-f 8" (for DVD). Why is it required that an MPEG-2 stream needs to know if the muxed file is for DVD, VCD or SVCD, requires data like VBV and more?
2. Question(2).
When I use mplex, and make a PVAStrumento "Scan", I get the following error after I muxed using mplex:
When I use bbmpeg for muxing, the error doesn't show up.Code:ALERT> -71583 video frames missing at 00:47:42.904. ALERT> Dropping GOP for sync. Re-syncing. Closing starting GOP. ALERT> 71583 video frames missing This is probably due to a cut in the source. ALERT> Dropping GOP for sync. Re-syncing. Closing starting GOP. Aiming for sync at 00:47:43.864 Cutting audio.
- Any idea why this is?
- Is there any other muxing tool other than mplex or bbmpeg?
- Is there any tool which allows analysing an MPEG-2 stream in detail (timecodes, flags, VBV, ...)?
Thanks a lot!
hi,
there's a software called Mpeg2Schnitt
and also --> ImagoMPEG-Muxer
unfortunatelly I cannot remeber it's homepage
try a google search
Two questions: Best free video converter & Best free muxing tool?
By milOtis in forum Video ConversionReplies: 7Last Post: 9th Jul 2011, 17:40 -
Please Help! Muxing for Itunes
By FaiT in forum Newbie / General discussionsReplies: 17Last Post: 24th Mar 2011, 12:20 -
need help muxing to vob
By ChrisDaMan in forum Video ConversionReplies: 8Last Post: 11th Mar 2011, 10:17 -
Muxing Quality
By BassJunkie in forum MacReplies: 2Last Post: 30th Jul 2008, 08:47 -
Screwed Up the Muxing
By Mnem in forum SubtitleReplies: 6Last Post: 16th Apr 2008, 15:40
