  1. I have downloaded some video, well what i thought was video, and when it finished it came in 2 files, one of them has the extention .BIN and the other is .CUE. I'm assuming that the .BIN file is the video and the .CUE is the audio . My problem is this, how can i play this file and how do i convert it to something more practical like and MPEG or AVI??
    Any help greatly appreciated and thanks in advance.
  2. First you can use isobuster to extract the mpg or dat file from the bin and play it with wmp. Or use the bin and cue files to burn to cd as vcd or svcd. Several burning programs will handle the bin, nero, dick juggler, fire burner, etc.
    find isobuster with google
    I have a small l*enis
  3. Member Treebeard's Avatar
    Aug 2002
    you can also mount the bin in a virtual drive using daemon tools and then just drag and drop the files to your hard drive or watch from there.
  4. gdsjr and Treebeard. cheers for the quick replies. I'm going to give that isobuster programme a try first, hopefully that should work, if not i'll resort to that daemon tools thingy, which sounds more complicated, but probably isn't!
  5. Originally Posted by gdsjr
    dick juggler
    Get too involved with that and you won't care about the damn video anymore. hehehe...
    Darryl
