What is the Best Way/ to Back up Hard disk via DVD R , DVD RAM to preserve all data without c orruption
0) for RAM , just drag and drop from hard disk into RAM ?
a) HAVE THERE BE ANY PROBLEM with XP reading FAT 32 data
1) for DVD R, I think Nero has a back it up function
a) if I need to transfer installed programs and all data to new computer ...USE " create new backup " ?
b) If I need just the had disk info to new computer ..USE " new drive back up " ??
Originally Posted by jameshgrossWant my help? Ask here! (not via PM!)
Me too, Norton Ghost. But i have a DVD-RAM drive, so no 'burning' involved...
I've tried R-DriveImage, it cam make a backup of the active partition, from the active operating system, onto the disk being archived, which is not bad if you have little space. Unfortunatelly it needs boot disks/CD to restore it, but what doesn't?
I have multiple primary partitions, and stick with GHOST for now, this way i can restore a primary from another primary...
Partition Magic, Boot Magic, Norton Ghost - That's about it, with these you can do everything, like resize partitons, backup, restore, boot from/to and convert. I have DVD-RAM, so far it is better for archiving than DVD-R (i backup files separate, not images...), don't have DVD-RW, so can't tell about that...
Edo -
Powerquest Drive Image 2002 is the only program that has been found by Maximum PC to work with SATA drives so that was my choice. After multiple frustating problems with Ghost and a hard drive rendered unusable that required a new format I could not be happier with Powerquest. The only problem is that Norton bought them out so don't look for anything but arrogant support if any.
Still a few bugs in the system... -
Nero can do it.
But, Nero backs up the entire partition, not just
the data.
So, it's a good idea to keep your OS(and prograqms) partition
small if you wish to back it up. -
I confirm Norton Ghost 2003 is better than Nero back it up function ?? ( TO BACK UP A NOTEBOOK )
1) which specific function of Norton Ghost
2) to back up an external hard disk
can I just use the following
a) for RAM disk , just drag and drop from hard disk into RAM ?
b) for DVD R, use Nero back it up function
TV to hard disk
By pannayar in forum Newbie / General discussionsReplies: 7Last Post: 11th Sep 2008, 19:21 -
Burning iso image from Hard disk to hard disk?
By When in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2008, 22:27 -
Hard Disk Advise
By tapal in forum ComputerReplies: 7Last Post: 26th May 2008, 17:55 -
DVDs on hard drive for back up and play back on TV
By yadoc in forum Video ConversionReplies: 2Last Post: 2nd May 2008, 20:03 -
hard disc 1 died, hard disk 2 won't boot, halp!
By Yoroshiku in forum ComputerReplies: 6Last Post: 30th Oct 2007, 13:48
