I have just spend days getting a 'perfect' 16:9 mpg file of a home movie. I had to use several apps and many hours to get what I want. Now the question is is how do I get this file on a DVD without re-rendering and messing up all the hard work.
The mpg is DVD compliant, VBR 16:9 interlaced with AC3 audio and abt 3.8gig which should fit fine.
My question is what program can spilit it into VOBs and create the IFO files without rerendering. I don't need fancy menus. Just want to put the disk in and let it play.
Thanks for any suggestions.
If it is compliant, then TMPGDVDAuthor or DVD Lab will do this for you. In fact, any reputable authoring package should be able to do this. Unfortunately, many insist on re-encoding for their own perverse reasons.
Is this a single file, or have you created seperate audio and video streams ? If it is a single file, DVD Lab will probable suggest demuxing when you import it. Let it do it, as this will not affect the quality. -
Downloaded the Trial of TMPGDVDAuthor 1.6 and it seemed to do the trick. However, it complained that the file was encoded at 20MB/s bitrate. Strange since other apps report VBR at max 8MB/s with avg at 5.5MB/s.
But it did create 3 VOBs at 1 gig and 1 with 800meg and the VOBs played fine with PowerDVD. DVD plays fine, too.
Thanks for you help.
How can I create IFO + BUP files for a VOB file?
By mac&me in forum MacReplies: 3Last Post: 4th Dec 2010, 03:06 -
Can I create an .IFO file from .VOB files?
By Madcap in forum DVD RippingReplies: 7Last Post: 15th Aug 2010, 15:57 -
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 16:12 -
How do I create VIDEO_TS IFO from VOB files
By stockton209 in forum DVD RippingReplies: 2Last Post: 8th Jan 2010, 04:07 -
create menu for 2 movies with several vob files with guifordvdauthor
By aruwin in forum Authoring (DVD)Replies: 1Last Post: 30th Dec 2007, 06:22
