    Oct 2003
    I have a DvD that has 4 or 5 large VoB files I have tried several different setting eveytime a little somthiing goes wrong on 1 of my attempts the Vob lost its sound half way thru the next time the picture just freezed up half way thru each time some of the vob's played fine but there were always 1 or 2 that didnt please help.
    do you mean when you play the vobs? what are you playing with? or what exactly???
    Oct 2003
    I have a training disk that about for or 5 vob's that are the actual training I decrypt them seperatly to my hard drive the I try to play them with the nero player and some work ok the 1 plays half way thru the the picture freezes.when I change the settings in DvD decrypter now the picture plays all the way thru but the sound cuts out half way thru.I hope I have answerd your question.Im at work so it dont have dvddecypter in front of me.
    Thanks for your time
    you could try play the vobs with another player like media player classic.
    but just playing vobs can cause problems. you should play a dvd by select the video_ts.ifo or video_ts folder with for example powerdvd, windvd, media player classic.
    Oct 2003
    I dont think its the player because when I try to convert these with mainconcept encoder into vcd's then try to play with either windows media or any other player I get the same results.
