Hi, I'm from Italy and I capture mpeg video with mpeg-1 hardware based capture device.
I want to create video cd from my ol vhs tapes and I use the provided software MP10 recorder.
In this software I can change various settings such as GOP and P frames.
Since capturing directly with 1150 KB/s, GOP 12 and P frames 3 I obtain a poor quality video with a lot of blockiness during playback.
I usually convert then with maximum quality of my capture box: 3000 Kb/s, gop 15 and P frames 3; then I convert the mpeg video with Tmpgenc in VCD compliant standard format and the result is very well but....Tmpgenc is too slow....
someone can help me to use a high quality fast encoder to convert my mpeg videos to high quality compliant vcd 2.0 files?
I'm sorry for my english. Thank you for your helps!
Hello,
I don't work with video cd much since I got my dvd burner but here is a list that might help:
https://www.videohelp.com/tools?s=9#9
I don't know which are faster than tmpgenc but one of them should help out.
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Codecia DV best settings for capturing Hi-8
By magillagorilla in forum Capturing and VCRReplies: 2Last Post: 2nd Dec 2011, 18:18 -
Capturing with Pinnacle Studio Ultimate 14 or should use another programme?
By avz10 in forum Capturing and VCRReplies: 10Last Post: 28th Jun 2010, 12:09 -
Problems Capturing HDV into Pinnacle Studio 11+
By lasereyes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 1st Mar 2009, 08:58 -
DVD autoplay settings in Pinnacle Studio 12
By lrios in forum Authoring (DVD)Replies: 2Last Post: 10th Feb 2009, 12:09 -
how to understand what settings to use for capturing
By Fking in forum Newbie / General discussionsReplies: 6Last Post: 15th May 2008, 18:50
