This happens when I hit start in TMPEGEnc trying to convert an avi to mpeg2 so I installed an mpeg2 codec to make sure and still get this. any help in appreciated. works fine with mpeg1.
Mike
TMPEGEnc has a time limit (30 days) for using it's MPEG2 encoding feature. Installing a new MPEG2 codec will not affect the operation of TMPEGEnc. Instead, you could just install a new copy of TMPEGEnc and remove the previous copy. This way you will have an additional 30 days to use the MPEG2 encoding feature.
Cheers,
ThighMaster -
Alternatively, make a "TMPGEnc_MPEG2_Reset.reg" file with Notepad (*.reg extension is mandatory, name can be whatever) with the following content:
REGEDIT4
; Enables TMPGEnc's MPEG-2 encoder for 30 more days.
[-HKEY_CLASSES_ROOT\CLSID\{63902277-B101-4049-8B46-C24B67E155E5}]
Double click this file when your TMPGenc expires and you'll get another month for free.
Simply removing/deleting will not permit one to re-enable the 30 day trial.
"1. Say you've accidentally destroyed a nice shareware program what has a 30-day trial period. Later on, when you notice that it's been destroyed, you try reinstalling it, only to find out that you can't, because the program thinks that you're just trying to get another 30 days. If you first remove the program's registry entries, however, you may very well be able to reinstall the software and recover your trial period again."
(from the help files)
Therefore, go here:
http://www.jv16.org/
and download regcleaner, follow its simple instructions. Download TMPGEnc and then apply the registry hack.
Delete Source Files after batch process has ended
By Metallo in forum Video ConversionReplies: 3Last Post: 24th Mar 2010, 19:10 -
In used Nero Trail Can not hear the comnversations for Music
By frankduffey in forum Newbie / General discussionsReplies: 3Last Post: 31st Jul 2009, 09:41 -
How I Ended Up Saving My Data From A Dead Drive...!
By tug_hill2 in forum ComputerReplies: 2Last Post: 25th Aug 2008, 11:56 -
As the Pats ended perfectly their season,...
By moviebuff2 in forum Off topicReplies: 9Last Post: 3rd Jan 2008, 06:51 -
Sony GX3 Motion Trail
By fubsy in forum DVD & Blu-ray RecordersReplies: 2Last Post: 15th Oct 2007, 12:12
