so when im ripping a dvd(i use a mac), i can keep the 6channel or the 2 channel audio.
what kind of effect is this going to have on my video if i chose the 5.1 over the 2 channel?
does the video quality even have anything to do with the audio?
You're only ripping to the computer right? So, it won't really matter. If you choose to have 5.1 audio, the outcome of the entire thing will be bigger in size than if you choose 2.0 audio. And no, nothing should happen to your video. It's only the encoding process to DVD that will affect video.
MKV & Adobe premiere: Best method to import without quality loss
By libjoe67 in forum EditingReplies: 34Last Post: 19th May 2012, 16:34 -
How to add selectable audio to a video without quality loss
By m.eshi in forum EditingReplies: 2Last Post: 27th Aug 2011, 10:09 -
old way of resizing mp4 with little loss of time & quality
By visible0 in forum Video ConversionReplies: 0Last Post: 15th Apr 2011, 01:13 -
Splitting VOB files with audio delay/quality loss?
By S0VIET in forum Authoring (DVD)Replies: 8Last Post: 30th Oct 2010, 22:48 -
How to split audio for editing without loss of quality in video?
By anindyanuri in forum Newbie / General discussionsReplies: 2Last Post: 15th Dec 2008, 21:26
