Results 1 to 9 of 9
  1. i dl a dvd ripp and the file is a ISO. how can i get the video out, so i can open with TMPGEnc?
    Mar 2003
    Uranus
    Mount it with Daemon tools or maybe isobuster will extract it
    Aug 2003
    Newcastle
    CloneDVD can burn directly from ISO.
  4. Originally Posted by calhoun
    i dont have a dvd burner
    i open it in isobuster and this is what it said
    vts_o1_0.ifo 64.00 kb
    vts_o1_0.bup 64.00 kb
    vts_o1_1.vob 1,023.83 mb
    vts_o2_2.vob 1,023.83 mb
    vts_o3_3.vob 969.00 mb
    video_ts.bup 8.00 kb
    video_ts.ifo 8.00 kb
    whitch file will contain the movie (video)? i not shore what theses files do please help
  5. Member Ironballs's Avatar
    Feb 2003
    Under me bird
    dblue,
    Use DVDDecrypter to burn the iso image, you won't need another re-encode. If you just want to see what is in the image, like a previous poster said, mount it on a virtual drive, try Alcohol 120%.
    And BTW, never, ever mention d/l and DVD in the same sentence, you're going to get banned!
    Cheers
    Ironballs
  6. Member Ironballs's Avatar
    Feb 2003
    Under me bird
    dblue,
    Just seen that you don't have dvd burner. Use Videolan to play the iso image.
    Mate, if I were you I'd shell out for a burner, DVD iso images are massive, and these days they are cheap to buy
    Ironballs
  7. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    ohhhh boy. You need to do a lot of reading.
    Start with The AUP. If this is what I think it is, you might be in a bit of trouble.
    Then read What is DVD (top left).
    Then read my DVD --> 1 VCD guide.
    If in doubt, Google it.
  8. Greetings Supreme2k's Avatar
    Feb 2003
    Right Here, Right Now
    The answer to your question can be found here.
  9. thanks guys
