Hi,
I am having great difficulty converting nearly any type of video file.
I have tried encoding AVI, d2v/WAV, asf to mpg using TMPGEnc 2.01 and it spits out the following error after about 10 min:
"Read Error occurred at address 0046D164 of module 'TMPGEnc.EXE' with FFFFFFFF"
and also the same error with 'DVD2AVI.vfp' when converting the d2v/WAV on TMPGEnc.
I definately know the problem is within TMPGEnc because I got one of my older VCD movies (the sixth day), I copied the .dat file onto the hard drive and tried to convert it into mpeg using TMPGEnc.
When I made this vcd (the sixth day) a couple of months ago it worked converted fine using TMPGEnc.
So I tried it again and the errors as above came up.
This happens all the time now, and is giving me the shits!
I know I am not the only one who has encountered this problem because there have been several posts similar to mine, but no one has had a direct answer for it.
Please if someone wnows how to fix this can they please speak up.
thanx.
hayward
If you are running WinME then i cannot help you since winME has crashing troubles with TONS of video software
No I am using win 98
and ive tried several times re installing the VFAPI plugin for TMPGEnc.
something else must be the problem but I dont know what!!!! -
Disable the Directshow in the environmental settings/VFAPI section, if that doesn't work, move it to a higer priority.
TMPEGenc h.264 conversion error
By iGnight in forum Software PlayingReplies: 2Last Post: 16th Jan 2011, 11:14 -
MKV to IPOD conversion error
By ganjasmoker in forum Video ConversionReplies: 6Last Post: 8th Nov 2009, 00:20 -
Error with FAVC Video Conversion
By IllusionOfLife in forum Newbie / General discussionsReplies: 3Last Post: 8th Sep 2009, 18:38 -
Auto GK conversion error:
By sibaroochi in forum Video ConversionReplies: 1Last Post: 28th Jan 2009, 06:26 -
Divx conversion error with VirtualDubMod
By newnews in forum Video ConversionReplies: 4Last Post: 8th Feb 2008, 16:15
