Hi,
To save place, I would like to burn on DVD either VCD or SVCD mpg files, if possible without losing their original quality with a recompression.
However it seems like no software allows for instance to use a VCD/SVCD structure on a DVDR media?
I think Nerovision could import my VCD/SVCD files to create a Video DVD, but then I guess it must recompress my files...
You can take vcd files and author them straight to DVD which will play on all dvd players...vcd video is DVD compatible. The authoring step does not recompress the video, it only creates the vob and other necessary DVD files using your vcd's.
SVCD video is not a valid dvd resolution. It can either be converted to a dvd resolution, or burned to dvd as-is which will not be compatible on all players.
For step by step guides look up VCD to DVD and SVCD to DVD under format conversion in the green All Guides section over there <-<-<-."Art is making something out of nothing and selling it." - Frank Zappa -
OK somebody told me where I could find what I wanted: http://www.svcd2dvd.com/
Avoid recompress in DVD Architect
By arcorob in forum Authoring (Blu-ray)Replies: 6Last Post: 29th Apr 2017, 16:59 -
How do I burn DVD ready .mpg files as a video DVD?
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 29th Nov 2011, 15:47 -
How To Recompress .FLV Video Files
By TonySan in forum Newbie / General discussionsReplies: 1Last Post: 13th Jul 2011, 17:00 -
Can I burn VCD or SVCD on DVD±R/W?
By Baldrick in forum Authoring (DVD)Replies: 111Last Post: 30th Aug 2008, 16:38 -
Burning VCD/Svcd mpg files to dvd without encoding
By Morb1ous in forum Video ConversionReplies: 4Last Post: 22nd Aug 2007, 16:56
