Under win2K how can you verify highspeed?
I looked under performance viewer and there isn't a counter for USB transport or interface, least I didn't see itI use that puppy for everything and it bums me that there's nothing for USB.
That being said, how can I tell I'm running at max speed for USB2?
BTW, I installed a new USB2/firewire card. Win2k would let me install VIA's driver. I had to use win2K's version. (device manager shows enfanced so I know at least it installed the USB2 version)
Task manager show CPU usage at a steady 50% with my P4 2.6ghz
Well, first this:Originally Posted by stiltman
Then your computer will crash.Task manager show CPU usage at a steady 50% with my P4 2.6ghz
Seriously you need a bus speed meter to tell how fast it's working or a benchmark. Onboard speed is set in BIOS, speeds for PCI cards are always at their highest AFAIK. -
Guess it's running at full USB2 spped. I transfered 60gb over to it and it only took like a half hour or so. I know when it was on my USB1.1 it took about 12 hours to transfer 40gb
I also did some search for problems and came across a few that said that their data (4gb files) was being corrupted. They tested it by using winRAR with recovery mode on a 4gb file, transferring it to a USB drive, then back again. They then tested the file via winRAR and it came up with errors. The bit count was the exact same too. I did the same test on a 6gb file, and I did not get any errors. -
Control Panel, System, Device Manager...
Under USB Settings you will see the word "Enhanced" denoted on one of the USB devices loaded -
Already said I saw thatOriginally Posted by DVD_Ripper
I was looking at a way to measure the actual speed, like you can on the IDE/SCSI interface -
Don't quote me but, I THINK SiSoft Sandra is able to test throughput on external drives.
Nothing can stop me now, 'cause I don't care anymore.
will a USB2.0 Firewire Adapter work for me?
By J.Frost in forum Newbie / General discussionsReplies: 22Last Post: 21st Dec 2009, 17:20 -
dvp5990, usb1.1 or usb2.0?
By twister6 in forum DVD & Blu-ray PlayersReplies: 7Last Post: 22nd Feb 2009, 15:22 -
Can I up from USB to USB2?
By jollyjohn in forum ComputerReplies: 16Last Post: 30th Aug 2008, 10:05 -
Pioneer DV400vk, using a USB2 HD
By Tom35 in forum DVD & Blu-ray PlayersReplies: 8Last Post: 27th Jan 2008, 16:44 -
DVD player HDMI + USB2 ?
By Roccos in forum DVD & Blu-ray PlayersReplies: 3Last Post: 5th Oct 2007, 11:30
