hi all, when capturing using my ati aiw 9600pro i get distortion.
I have an audigy zs platinum and my settings are set to "audio mix" Line In the audio distorts only in the right side when wearing headphones, theres a flutter or little humming noise![]()
I've lowered all of my audio options still there is that noise any suggestions pleasse help![]()
I had an old ATI AIW 128 pro 32mb agp card on a windows xp pro system. It had distortion in the audio, basically as if the sound was too loud. Turned out that several sources suggested going into the registry in the ATI software section and set the audio capture value to a much smaller value. I don't remember the specifics, but if this sounds like an option, please let me know and I will dig up the specifics.
I am sorry, but I cannot find my notes on that fix. I have sold my old AIW and am getting a TV Wonder Pro next week. When I install it, I will try to recall the settings and get back with you.
Originally Posted by syeagerWant my help? Ask here! (not via PM!)
It was a AIW 128 pro. I needed to upgrade my video so I bought a ATI 9500 pro. I was going to go with a Compro VideoMate Gold+, but the image was inferiour to the old AIW. So, not being able to pony up the $200+ for newer AIW, I adding the TV pro. With this setup, how much and what do you think I will lose?
Originally Posted by kandiman
https://www.videohelp.com/forum/viewtopic.php?t=206625&highlight=
mastersmurfiejust a thought
mastersmurfie
Distortion in audio
By carlmart in forum AudioReplies: 2Last Post: 3rd May 2011, 13:59 -
Audio distortion
By silveringking in forum AudioReplies: 0Last Post: 26th Jan 2011, 16:13 -
My TV Caps have Low Audio Volume and Hiss - ATI AIW 2006 PCIE
By somebodeez in forum Capturing and VCRReplies: 16Last Post: 26th Apr 2008, 07:08 -
ATI Aiw card in Linux?
By Nelson37 in forum LinuxReplies: 9Last Post: 10th Apr 2008, 13:25 -
ATI AIW 9800 audio issue
By saggitarius in forum Capturing and VCRReplies: 1Last Post: 27th Jul 2007, 15:17
