BenQ DW822A
LG GSA-4082B
LG GSA-4120B
LiteOn SOHW-1213S
LiteOn SOHW-812S
NEC ND-2500A
NEC ND-2510A
Pioneer DVR-107
Pioneer DVR-A07
Pioneer DVR-A07XLA
Toshiba SDR5272
So which dvd rw should I get from this list? I would need the following requirements:
-it will be my only dvd drive, so it has to be a good reader.
-it needs to burn well with cheap dvd +/- media
-bitsetting capability
-dual layer would also be nice
You will soon get NEC ND-3510A which I have ordered. It is a better deal. Otherwise NEC ND-2510A is also very nice. Been using it for about 5 months.
Why don't you try Pioneer 107? I had one for about 7 1/2 month, and it is still working fine. And the price is just fair and fine to me. Exactually I bought an NEC 2500A at some time, but NEC just got retired way earlier than Pioneer.
I'd get the Benq. Once you burn a few +R bitset to DVD-ROM with it you will fall in love. It is fast, produces great write quality, set and forget bitsetting, and should have a dual layer firmware by the end of September. From your list, I don't have any experience with LG or Toshiba drives, but I have used some Pioneers, NEC 2510a and 1 Liteon (411S). After the Benq I would choose the Pioneer but it doesn't meet your requirements, no bitsetting or +R DL support. Also look at what each of the companies has done in the past as far as supporting older drives. NEC and Pioneer don't seem to put much more than added MID codes to new firmwares where Benq has added new features. And I don't mind a company adding features to a firmware and selling it to me for $10.00, any of the rest of them going to do that over sell you a complete new drive?
Thanks for the info ccbadd, I was thinking of getting the BenQ as well. I just have a quick question though
Originally Posted by ccbadd -
I think I heard BenQ was going to offer the DL support firmware for free, do you know if that's true?
Some other things to look at:
Did you notice that only a few drive manufacturers upgraded there firmwares to support 4X -/+ RW media to existing drives after the spec became official? They added it to later version of there hardware, but there was no technical reason that a drive that could -/+ media @ 4X could not add 4X -/+ RW support over 2/2.4X support that was already there. -
Bank on Benq
The electronic components of the power part adopted a lot of Rubycons.
DVD+RWs no longer play
By Iconoclast in forum MediaReplies: 31Last Post: 26th Mar 2012, 20:59 -
Trying to use DVD+RWs with Imgburn and Megastor 16xDVD9
By w6rlf in forum Newbie / General discussionsReplies: 2Last Post: 4th Feb 2012, 23:02 -
Archived unfinalized DVD-RWs--can i play them?
By mpmp0 in forum Newbie / General discussionsReplies: 23Last Post: 30th Aug 2008, 22:31 -
DVD+RWs going bad
By lmemsm in forum MediaReplies: 18Last Post: 12th Jun 2007, 13:40 -
Problem formatting DVD+RWs
By Sephiroth666 in forum MediaReplies: 12Last Post: 12th May 2007, 12:51
