Does anyone know what the normal amount of Pl errors and failures are for DVDs? On every DVD I've tested with Nero Disc Quality Test, I always end up with a disc quality of like 70% or below no matter what discs I am using. Is this normal? On CD's I've tested I get very few C1 and C2 errors, but DVD's seem to have a lot of Pl errors.
The DVD's I've tested were all burned on various Pioneer burners (104, 105, 106). I am using a Sony DDU1612 DVD-ROM for testing (supposedly a rebadged Liteon 166). All DVD's are various brands, supposed high quality "made in Japan" stuff. I get no errors on ScanDisc file test or surface test, only using Disc Quality Test.
Which test is this exactly?
The test is found in Nero CD-DVD Speed under the "extra" heading. It's called Disc Quality Test, right below ScanDisc.
cdfreaks.com has a lot of forum space talking about PI/PO tests - another product called KProbe also does these tests. You can find a lot of information over there about them, but I can tell you that what I've found is while low PI/PO numbers are good, high ones aren't necessarily "bad" - I normally run the normal Nero disk scan and as long as they're all green - it's normally a keeper.
I've also used a product called DVD Inspector, which shows counts of "soft" and "hard" errors, and as long as soft is below about 2% and hard is 0, it's a "keeper".
Cheers...... -
This link specifically talks about PI and PIF errors and has many examples. A very good place to start.
http://club.cdfreaks.com/showthread.php?t=80545Still a few bugs in the system...
Test of various VCRs Image Quality from VHS Tape (Big Pics)
By BrainStorm69 in forum RestorationReplies: 47Last Post: 2nd Aug 2013, 15:58 -
Nero - Compliance test failed? whats up w/ this?
By BRYAN_B28 in forum Authoring (DVD)Replies: 11Last Post: 2nd May 2012, 01:13 -
[b][url]TEST! TEST TEST! WHAT"S THE BEST?!!!!!!!111111
By lordsmurf in forum TestReplies: 0Last Post: 2nd Aug 2010, 02:30 -
Test of SUPER-VHS playback quality for various VCRs
By theaveng in forum RestorationReplies: 5Last Post: 20th Aug 2008, 08:09 -
Nero "Disc Quality" test?
By tac7 in forum DVD RippingReplies: 2Last Post: 12th Jun 2007, 17:40
