    Jul 2004
    Scotland
    a movie i watched on my pc had white kind of glowing patches mainly in the background of the scenes...the characters in close up werent affected just seemed to affect the background...the sky the sea like a really white glaring.....also the ground looked similar....Is there a technical name for this fault?......If so what causes it and can it be fixed. Thanks in advance
    Today is the day you worried about yesterday - And your still here......So whats the problem huh.
    Apr 2004
    Miskatonic U
    Who says it's a fault ? It may have been a deliberate choice on the part of the director and DoP to process their film in this manner.
    Or it could be the sun in the background
    Or it could be that you have the brightness turned up too high on your monitor
    What's the film ?
    Jul 2004
    Scotland
    It looks an obvious fault to me, the film is Troy. The quality of the film looks good apart from this glaring , even in some close ups on the actors who have greying beards the beards show up brilliant white.....like you cant even make out the facial hair just this white shape as white and plain as the background this text your reading appears on. same with most distance shots of the sea,, sky and and certain shots of buildings. When its a nightime scene everything looks great the problem isnt there. Any ideas?
    Jan 2002
    Not the end of the world!
    # Do NOT give warez.
    # Do NOT link to warez .
    # Do NOT ask for warez.
    # Do NOT provide information how to obtain warez.
    # Do NOT advocate warez.
    # Warez includes downloaded copyrighted movies, movies that are not yet released on VHS/DVD and copying rented movies.
    Troy has not been released on Video.
    Jul 2004
    Scotland
    My apologies, i did however try and word the original post so as not to advocate any of the above mentioned. It wont happen again.
  6. Sounds like a screen shot film. You are probably seeing reflection from the screen, sometimes called "hotspot" (though that may or may not be the right term for it). There is probably nothing you can do about it. The detail in that section likely cannot be recovered. You can darken it, but the detail will not come back. This is typical of screen shot bootlegs. You just have to live with it.
    Darryl
