I'm caturing with a WinTV-Go and VirtualDub on an Athlon 1.4 GHz system in 352x576 and observed the following: If I capture from an analog satellite tuner, no frames will be dropped (15%-30% CPU load). If I capture from VCR, I will get 0.5% dropped frames for new recordings on high quality tape and up to 30% dropped frames for older recordings on medium quality tapes. The CPU load is 30%-50%. Does anyone have an explaination for this? The visible difference between the recordings is not that high. Would a signal intensifier used for VCR to VCR copies help?
dirk67,
That's strange. But then again. . .
It could just be that there's still too much bandwidth goin on there.
I've done a lot of VCR captures - from 1 min. caps to over an hour
with my DC10, and I've never had any frames drop! I've capped
from my regular VCR and from my S-VHS - no drops in frames.
The only time when I do drop frames (can be many) is when I
FF or RW during my captures. Then I drop frames, and sometimes
pretty crazy.
I think it may be due to lack of bandwitch. I'm gonna have to test
this out myself, but with the hauppage wintv pci card I've ben testing
for the last couple of days. Its a little too late right now. maybe
tomorrow - I don't know.
DC10+ Samples
<font size=-1>[ This Message was edited by: vhelp on 2001-11-20 00:05:15 ]</font> -
vhelp,
thanks for your answer. What bandwidth do you mean? In the analog signal? Or in the captured data? The latter cannot be the case, because the data rate is always the same (about 200 kb per frame or 5 mb per second with huffyuf). It seems to depend on signal quality and/or noise in the signal. By the way, the satellite tuner where all works well is connected through the VCR, so it cannot be the cable.
AverMedia HD DVR - Frame drops in live playback
By Anonanon in forum Capturing and VCRReplies: 3Last Post: 1st Mar 2012, 02:11 -
Joining 2 TS streams produce glitch and frame drops
By arminio in forum DVB / IPTVReplies: 8Last Post: 7th Jun 2011, 03:30 -
MPEG II Video Quality drops using Any Video Converter...
By Spoilerone in forum Video ConversionReplies: 9Last Post: 10th Feb 2011, 12:30 -
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 17:26 -
Question about Quality between I-P-B frame
By Starkian in forum Newbie / General discussionsReplies: 5Last Post: 12th Jul 2008, 02:52
