How does one finalize a dvdr OUTSIDE of the regular burning process (as used in CopyToDVD and Nero)? can this be done (assuming it was not done by these 2 apps during the original burn) with another app after the burn? thanks for all replies.
alright you dvd gurus, don't be shy
Okay another quick Q...does the creation of the Lead-In and Lead-out blocks constitute a finalized media? thanks.
Well i would have thought as you can only use a dvd-r once if you fail to finalise then you cant do it in another program. Could be wrong, just my best guess. If you were using dvd-rw then thats another story.
On the second post no idea....
Not bothered by small problems...
Spend a night alone with a mosquito -
With Nero:
1-Insert the unfinalized disk into your drive
2-Open nero (with classical interface not the wizard)
3-Under multisession choose continue multisession
4-Under burn choose write and finalize
5-Press New
6-Press burn button
Finalizing a DVD
By calili in forum Newbie / General discussionsReplies: 7Last Post: 29th Mar 2010, 16:40 -
Finalizing a DVD
By gmcsew in forum MacReplies: 24Last Post: 18th Jul 2009, 23:07 -
What happens to the disk when finalizing?
By hurricane1951 in forum Authoring (DVD)Replies: 3Last Post: 19th Sep 2008, 23:54 -
Finalizing
By JaredKnight in forum Newbie / General discussionsReplies: 2Last Post: 30th Sep 2007, 08:53 -
how to finalizing a dvd+r ...
By jvlbr in forum Newbie / General discussionsReplies: 6Last Post: 6th Jul 2007, 22:29
