  1. Anonymous
    Guest
    when u capture an analog video signal,what is its format called? like mpeg,mov etc. I need to find a conversion guide from vcr to dvd.
  2. drink up....the world's about to end
  3. Going Mad TheFamilyMan's Avatar
    Jan 2004
    south SF bay area, CA USA
    why bother......
    Usually long gone and forgotten
  4. Originally Posted by Dr.Gee
    Will you be copying the video to a CD with menus to play in your car or home stereo system
  5. Going Mad TheFamilyMan's Avatar
    Jan 2004
    Did I just fall for some kind inside joke? I failed to notice the thread count of 1000+ of the original poster ... a newbee with this high of a post count? A flame seems to be in order here.....for at least one poster to this thread.
  6. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I don't think so. I had around 2000 posts before I bought an ADVC-100 and started analog capturing. People may have knowledge in some areas but not in other. If I bought a MAC tomorrow, I would be a 2800+ posters with the most noobish questions in the MAC forum.
    anyway...
    Dr Gee, the file type is determined by how you are capturing the signal ie. if using a vcr hooked up to an ADVC-100 (like I do), you capture to DV AVI. If you are using a TVTuner card it will more than likely be capturing to MPEG.
    How do you plan on hooking your VCR up to your computer ?
    If in doubt, Google it.
