And just to compound your embarrasment, a Faraday cage
is for electric fields.
Results 31 to 34 of 34
Beware, I think Celine could demagnetize the speakers!!!!!!!!!
You caught me. I'll take my fifty lashes nowOriginally Posted by FOO
FOO wrote:
Above can lead to misunderstanding.And just to compound your embarrasment, a Faraday cage
Faraday Cage is used to shield electro-magnetic-waves, like radio waves.
The pulsating magnetic waves generate electicity in metals like wires and circuit boards.
Higher the frequency to be shielded, the smaller the cage-holes. Hi freq have short wave lengths.
Sun spots produce magnetic waves, sometimes poweful enough to overload powerlines with electricity, which trips circuit breakers.
Pulsating magnetic lines is how municiple electricity is generated. Wires are spun in a magnetic field to generate electricty in the spinning wires (alternator) .
Conversly, movement is generated by electrified wires in a magnetic field (motors).
Magnetic Shields are usually a capped cylinder made of iron alloy.
Magnetic fields take the path of least resistance thus, they flow in the iron and not in the air inside the capped cylinder.
Audio isn't playing out both speakers after turning VHS into a DVD...
By littleBIGworld in forum Newbie / General discussionsReplies: 4Last Post: 19th Feb 2011, 02:44 -
Is it safe to sell our free cell-phones? Also, is it safe to BUY?
By siratfus in forum Off topicReplies: 3Last Post: 12th Dec 2009, 16:30 -
Does 7.1 audio limit the rear speakers and divert to the side speakers?
By yoda313 in forum AudioReplies: 0Last Post: 4th Oct 2009, 10:55 -
Can I use the 5.1 speakers from my home cinema system without the dvd play
By leeuk321 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 2nd Aug 2009, 18:29 -
Speakers placement with tv, DVD player, etc (interferances?)
By DVinci in forum ComputerReplies: 6Last Post: 23rd Jul 2007, 19:50
