I've looked at the writers section and reviewed some of the posts here in the forum. I'm going to be getting a new burner soon, and I kind of like the idea of being able to use DVD-RAM for backups and other things. Also I've seen some good clearance deals on RAM discs at my local WM. Almost everyone speaks highly of the NEC 2510, but I was wondering if there's anything that it can do that the LG 4120B doesn't do, or does much better than the LG to warrant forgoing DVD-RAM.
TIA
Nothing can stop me now, 'cause I don't care anymore.
Anyone?
Nothing can stop me now, 'cause I don't care anymore. -
The NEC is more popular so it does have the advantage of getting more unofficial support(hacked firmware). Hacked firmware helps the NEC have a higher tolerance toward lower quality media and I think it allows it to add bitsetting for +R. Other than that I see real advantage over the LG. CDRinfo released a review for botht he NEC and the LG. If you stay away from low quality media (Princo, CMC and the like) you should have no issues with either.
The most popular aspect of Herries hacked firmwares is that it supports burning many types of 4X certified media at 8X.
WesleyTech.com - Blu-ray Disc & consumer technology news, reviews & articles
lg gsa-4120b dvdwriter
By mustang1967 in forum DVD & Blu-ray WritersReplies: 1Last Post: 30th Jun 2008, 00:50 -
NEC NDH80 Gone B&W
By bawpcwpn in forum DVB / IPTVReplies: 1Last Post: 11th Jun 2008, 15:23 -
NEC AD-5170A Questions
By urb1972 in forum DVD & Blu-ray WritersReplies: 1Last Post: 24th Nov 2007, 21:39 -
NEC 4571A problem
By rmorrison1 in forum DVD & Blu-ray WritersReplies: 18Last Post: 1st Jul 2007, 13:35 -
NEC NDH81
By babagoi in forum DVD & Blu-ray RecordersReplies: 0Last Post: 24th Jun 2007, 20:05
