I've been converting an educational VHS collection to DVD (firewire->iuvcr (pic vid mjpeg v3)->procoder2->dvdlab) and have not been happy with the audio quality of the originals (majority of which is dialogue)....
I'm looking for software that I could clean out some "buzz" and enhance the quality a bit on a budget. I don't see any need for a full blown professional grade audio prog.... just something to clean it up before incoding...
Any suggestions? TY
The cheapest yet still very capable solution would be GoldWave.
SoundForge is great but a bit on the expensive side of things.
However I guess I am the only one that caught a problem with your setup.
You don't want to go FIREWIRE to iuVCR
If you really are to "capture" via FIREWIRE then you are "capturing" DV AVI be it from a device such as the popular Canopus ADVC-100 or through a digital camcorder (using the analog pass-through feature).
So if you are doing DV AVI you want to "capture" it that way and I have put that word in quotes three times now because a DV AVI "capture" is really just a digital transfer of digital data.
Are we talking buzz as in a 'hum' type buzz? If so, you may have a ground loop issue. I've known people that went to extreme measures to reduce hum/buzz in their audio when all they needed was a ground loop isolator on the audio lines. ($10-$15 at Radio Shack) Of course if this isn't the problem it won't help you, but if it is the result can be quite good after installation.Originally Posted by upshot
The same can apply to video signals. Often some artifacts aren't on the tape at all but are actually introduced when interconnecting components. That's why I also use a video isolator on my inputs to prevent any interference whatsoever. (these are more expensive though - about $100)
Regards,
Savant
Recommend a budget desktop
By SIZZ in forum ComputerReplies: 4Last Post: 8th Feb 2011, 12:08 -
SD vs. HD (documentary and on a budget)
By Aheiden in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 17th Mar 2010, 01:55 -
Video Lighting on a Budget
By bowmah in forum Newbie / General discussionsReplies: 10Last Post: 24th Sep 2008, 17:07 -
distorted audio after transcoding thru Premiere to Cleaner
By noki in forum EditingReplies: 0Last Post: 8th Aug 2008, 07:36 -
Low budget DIY
By guns1inger in forum Off topicReplies: 2Last Post: 17th Sep 2007, 03:31
