Iv'e been downloading and burning for quite a while with good results, but I lent a friend a couple of movies he said that on his TV one is tall and thin and the other is about the size of a letterbox. I have deduced that because I have wide screen tv and he only has a normal bog standard one that the problem must be there. What format do I need to convert them to rectify this. I use cucusoft, tempenc/ and main concept and then burn with nero.
Tell your mate to BUY a telly made this millenium.......why waste YOUR effin TIME time?
Hello,
Use "keep aspect ratio" to maintain the same 2.35:1 or 1.85:1 ratio. It will still have the black bars but won't be stretched or shrunk.
That's not very helpful. Besides, I don't have a widescreen yet. I'm gonna wait until I have to here in the US (when they force hdtv on us- I want it I'm just not ready to spend $1000 US or more yet).monzie-Tell your mate to BUY a telly made this millenium.......why waste YOUR effin TIME time?
Got to admit I'm a bit baffled by the US.......do you have normal (non HDTV) NTSC widescreen tellys (as we Brits/europeans do.....with PAL)?
Isn't it you guys (via the motion picture experts group blah blah etc) that came up with the standards in the first place?
Hell, you'd STRUGGLE to buy a 4:3 telly overhere nowdays (or for the last 5 years....)
And if you've got a ws and an .avi enabled DVD player (or TV out on your pc) the TV can correct/fill/zoom/crop video to your liking..plus the hardware as well.
So.....whats the standard for new TV's in the US (or Canada)...is it still 4:3? -
Hello,
Well as far as I know most of the new tvs here are NTSC 16:9 HDTV READY (ie all you need is a hdtv tuner to accept broadcast signals - some have them built in now). There are other variants like edtv and other hdtv knockoffs.monzie-Got to admit I'm a bit baffled by the US.......do you have normal (non HDTV) NTSC widescreen tellys (as we Brits/europeans do.....with PAL)?
I assume it was us who pushed it. Though, I think Japan was the first to come up with a modified hdtv (although I think it bombed because it wasn't up to snuff).Isn't it you guys (via the motion picture experts group blah blah etc) that came up with the standards in the first place?
No. It will be 16:9. Any new tv will be the widescreen format. Though as I mentioned there are some models that use "fake" hdtv specs - fake in that it doesn't offically say hdtv. Just a way to get people to spend $1000 USD on something they thought was real I guess.So.....whats the standard for new TV's in the US (or Canada)...is it still 4:3?
Hope this helps.
Kevin
P.S. I'd have to check the stores but I think you MIGHT still be able to buy a 4:3 square tv, though that would be tough.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Realplayer files to another file format or dvd format
By vieya in forum Video ConversionReplies: 8Last Post: 25th Dec 2009, 13:12 -
Converting raw DV format into a quicktime or MPEG format
By Maiden in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 80Last Post: 27th Apr 2009, 21:00 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 10:15 -
Converting from DVD format to playable on MAC format...
By livvyramone in forum MacReplies: 2Last Post: 23rd Jul 2008, 09:21 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 11:38
