  1. is there a way to play vcd's on a ps2
  2. ps2 can't play mpeg1.
    drink up....the world's about to end
  3. Never has. Never going to.
    If you get a qcast tuner, you could ftp it to your ps2 though.
  4. The PS2 can play MPEG-1. It can't play VCDs or SVCDs but if you author a DVD with MPEG-1 it should work.
    I had a few problems with MPEG-1s authored with TMPGEnc DVD Author with a menu, but without menus they worked fine.
    My PS2 model no is: SCPH-390003. Might be different for other models.
