  1. I have a VCD that plays video and audio fine with PowerDVD. If I put the VCD in my DVD player it plays video, but no audio. If I put it in my PS2, it plays audio only, no video. Obviously, if it can play audio and video using PowerDVD then the audio is on the disc, so just wondering how I can convert what ever is needed to play the audio and video on my DVD player?
    Thanks,
    Nathan.
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    You could check to make sure the vcd is 44.1khz audio (vcd standard) and 1150 video bitrate. If it isn't you could demux it with tmpgenc and reencode it. Other than there's not too much you can do (that I know of).
    Good luck.
    Kevin
