  1. Background info:
    At present I'm capturing using Matrox RTX-100 via firewire which creates a AVI file at full D1 720x576. I then load this file into MainConcept 1.4.2 and encode to DVD compliant half D1 format as the Matrox RTX-100 & Premier Pro dosen't support 352x576 resolution. Mainconcept works well and can output elementary video and audio streams.
    Now here's my problem.
    If i capture directly via firewire with MainConcept 1.4.2 from my Canon XL1-S PAL DV camcorder Mainconcept 1.4.2 always creates a multiplexed *.mpg file. I select audio output to *.wav and multiplexing = none but still end up with a all in one *.mpg. What additional setting do I need make to give me seperate video/audio streams.
    The reason I need seperate files is because I can edit the wav prior to creating a DVD with DVDLab or DVD_Author
    I hope you understand what I mean. Any assistance would be very welcomed.
    Thank you very much.
  2. Member spidey's Avatar
    Apr 2001
    U.S.A.
    I would simply demultiplex your captured mpeg to it's ES in TMPG
    Open TMPG - go to Mpeg Tools - go to Simple Demultiplex to get your
    m1v/m2v and mpa
    Then, you can encode the mpa to 48khz, then ac3 it prior to importin it into your authroing proggy
    ~~~Spidey~~~
    "Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards
  3. I'm almost positive you can not split the MPEG capture into V and A streams. Use TMPEG as denoted above.
    What authoring program requires two sep streams?
  4. Just do like these guys said.
    It only takes a minute or so to demux in tmpgenc.
  5. Just drop it into DVDLab - it'll demux the MPG for you, and save the mpa/mpv files under the same name in the same directory.
    I want the Star Wars O-OT on DVD, dammit!
