Hello
I have a J.V.C dvd recorder ( DR-M10 )
and i just want to know when i record a movie from the tv how can i
remove the channels logo
Like this one how can i remove the CNN logo :-
THANK U IN ADVANCE...![]()
- Non Mollare Mai -
Morning,
Sorry, at present the only way to do this without a PC would be to use a very expensive broadcast graphics mixer unit. However, if you have a PC with a DVD writer then you can do it inexpensively.
The method I have used to do this is to record at the highest possible quality onto a re-writable disk (RAM/+RW/-RW depending on your flavour of recorder) then rip it onto your PC
Then get a copy of VIRTUALDUBMOD (this version opens mpeg files) and the delogo filter. then re-encode (see the guide on how to do this in detail) using tmpgenc or CCE (tmpgenc is cheaper - 30 days is free with no watermarking). The only downside is that most logos still leave behind a blurry section where the video has been "repaired". Some logos can be removed using what is called alpha blending but these are normally only the semi-transparant logos/captions.
The resulting mpeg file can then be authored onto DVD using DVDLAB or your own flavour of DVD authoring package.
I realise this is quite a 'techy' answer but it will hopefully point you in the right direction.
Cheers
Edz -
Thank you so much ((wingnut))
and i have a Q if you dont mind :-
Q. Every time a record a movie from the T.V Then i take the (DVD-R)cd
from the DR-M10S and put it in another dvd player it doesnt play the
movie i recorded.what is the problem..?? please HELP
thanks again ( sorry for my bad spelling
- Non Mollare Mai - -
Hello,
I don't have a standalond dvd recorder but most of the time ANY dvd/cd needs to be finalized to be read on another player. Is this part of the problem?
I thought all dvd-r/rw(?) media had to be finalized before it is possible to play it...Originally Posted by yoda313
Could also be that you need som third party software to be able to play the files from your recorder...
I don't have a dvd recorder either so I'm not 100% sure...10110101100111012011 <- The bug Bill doesn't talk about. -
Hello,
Actually, I think if you have the same udf info you might be able to read it (ie if both pcs have roxio/pinnacle/whatever they can read the unfinished disc??? --not 100% sure---)Originally Posted by p0rnLiME
thank's ((yoda313 & p0rnLiME))...
I really don't now how to (finalized) a DVD-R...!!!
and i just recorded a soccer match..and i selected (SP) because the match was about 2 hours ok when i got back it only recorded 75 min
... why.....did i do some thing wrong or what..
and after it recorded the match i took the (DVD-R)cd out form the M10S and
put it in my Panasonic LX9 Portable dvd player but it didnt work..why..?
PLEASE ANY ONE HELP MEEEEEEEE...
Don't know why it would have only recorded 75 minutes, unless there was something else on the disc, or you used the ITR and didn't set it long enough. The discs have to be finalized to play in players. Hit the set up button on the remote, go to utility, then finalize. That will make the disc playable in players.
5.1/6 Channels to 2 Channels?
By tmac2085 in forum AudioReplies: 24Last Post: 10th Nov 2011, 21:54 -
trying to extract the 7.1 channels (8 channels) from Blu-ray disc
By billsantos in forum AudioReplies: 2Last Post: 20th Feb 2011, 16:28 -
streaming all tv channels available.
By TinkerThinker in forum Video Streaming DownloadingReplies: 0Last Post: 9th Aug 2009, 16:04 -
MKVs: downmix ac3 6-channels to ac3 2-channels and remux
By kwanbis in forum AudioReplies: 4Last Post: 10th Mar 2009, 17:07 -
QAM channels
By sorinicu in forum DVB / IPTVReplies: 7Last Post: 26th Nov 2007, 00:07
