Hi
I found a DVD player Marantz PMD930 that has this feature that hides the on screen display, like when you hit play, play won't appear on your screen. I was wondering if anyone knew of other dvd players that had this feature?
Thanks!
Could you give me specific model numbers and is the feature called the same for Panasonic?
Both of the recorders I've used do it DMR-E10 DMR-E20 the DVD-A120 player too. I have a couple of 5-disc players too, but I will have to check to make sure they do it since I have never tried to do it on them. I don't know what it is called, but you just go into the setup menu and turn the on screen display off.
Does anyone know of models that play DVD+R DL (dual layer DVDs) that I created and also hide the on screen menu/display?
I check with my Panasonic DVD player at home and I can hide the menu.
VLC : OSD time changing from hh:mm:ss/hh:mm:ss to hh:mm:ss.xxx/hh:mm:ss
By Bonie81 in forum Newbie / General discussionsReplies: 0Last Post: 18th Nov 2011, 08:20 -
Neuros OSD or Something Like It?
By justapilgrim in forum Capturing and VCRReplies: 7Last Post: 28th Feb 2011, 20:36 -
Need codes to convert Australian DVD player into a multi region DVD player
By Seajacb123 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 13th Oct 2010, 02:00 -
osd/coverart
By Marccc in forum Newbie / General discussionsReplies: 0Last Post: 30th Sep 2010, 07:24 -
PowerDVD - using OSD panel?
By terrypin in forum Newbie / General discussionsReplies: 1Last Post: 10th Dec 2008, 04:12
