Hi Guys,
I have a ORIGINAl Video with these settings:
Iīm trying to convert inside the TMPGENC with the settings in these imagens:
But when I start the convertion, I have this error message:
What is the problem???
Goya[/img]
Results 1 to 13 of 13
you realize that you have a pal (25 fps) avi that you're trying to conver to ntsc (29.97 fps)
might want to look up some pal to ntsc conversion guides. -
I don't know the exact cause of your error but I did notice a couple of things that you may or may not be aware of that may or may not be contributing factors:
Your source is PAL, yet you are converting to NTSC.
Source audio is MP3, which has been known to cause problems with TMPGEnc (even though you aren't using the audio in this case).
The first thing I would try is to save the video part out into a separate file. Load your source into VirtualDub. Go to Video > Direct Stream Copy and Audio > No Audio. Go to File > Save AVI. Specify a filename and hit Save. Then feed this new AVI into TMPGEnc.
BTW, well done on posting all the settingsIf in doubt, Google it. -
Hi jimmalenko,
So... the mp3 audio isnīt the problem because when I convert the video, I convert without audio. As you see, I select ES(Video Only) in the TMPGENC.
Iīll try to convert this video inside the VidtualDub to create a new avi video. But When I make this convertion... i have lost of quality or not???
Thanks,
Goya -
Hi dafreak,
Is not possible to convert a pal video (25fps) to a NTCS(29,fps)???
Goya -
The point we're both trying to make re: PAL or NTSC is that it is much easier to keep to output in the same format as the source. You don't have to worry about getting things in sync for one.
But if you want tackle a PAL-->NTSC conversion, don't let us stop you....
You won't lose any quality from pulling the video out to another AVI because we had DIRECT STREAM COPY selected on the Video menu.If in doubt, Google it. -
I suspect a bad AVI. Have you scanned it for bad/undecodable frames and stuff?
/Mats -
Hi jimmalenko,
Ok... so... iīll try to, first, convert with VirtualDub and than use the TMPGENC.
But, sorry my bad english... i canīt understand this part:
"But if you want tackle a PAL-->NTSC conversion, don't let us stop you.... "
What itīs mean "don't let us stop you.... "
Thanks again man!
Goya -
mats.hogberg,
I never do this... why can I scann it for bad/undecodable frames and stuff??
Goya -
bad frames or corrupted files can cause encodes to fall over.
I was trying to say that you can do a PAL-->NTSC conversion if you wish, but I would advise against it if possible because you would be making things unnecessarily harder for yourself.If in doubt, Google it. -
Originally Posted by goya
/Mats -
As above concerning the PAL to NTSC.
Next, you avi has a AR of 1.82:1 (640/352 =1.818) so you should consider encoding at 16:9 and not 4:3 as the "352" is flagged as the error...the vertical res needs to be set at 464..with 8 T&B (for NTSC) or if keeping in PAL 560 V also with 8 T&B.......and as an added bonus wave goodbye to those nasty THICK black bars (you wont even notice 8 thick borders, much).
HTH
SOS! I have output file from convert by mencoder but i don't know conmand
By zerround in forum Video ConversionReplies: 0Last Post: 24th Feb 2012, 01:38 -
Tmpgenc Xpress 4: I Don't Want To Resize
By Tom Saurus in forum Video ConversionReplies: 17Last Post: 16th Nov 2009, 14:18 -
Subs don't show properly I don't know what to do
By atai in forum SubtitleReplies: 1Last Post: 8th Oct 2009, 07:44 -
I don't know how to convert vob to mpg
By szalaikornel in forum Video ConversionReplies: 1Last Post: 12th Jan 2009, 07:18 -
Sony .MPG files don't work on Mac? Is that true? Can I convert them?
By zernalaw in forum MacReplies: 2Last Post: 30th Nov 2007, 13:15
