I'm converting old vhs-c tapes to dvd. I'm using VirtualDub to capture and TMPEGEnc 2.5 to convert. I'm not sure that I'm satisfied with the converted mpg's though. There seems to be more blurring and less detail than I would like to see. Check out the older man's striped collar on the left to see what I mean or the toddler's face directly in the center across the aisle.
Click here to see the original avi.
This is the same clip converted to mpeg-2 using LordSmurf's guide without noise reduction.
This is the same clip using LordSmurf's guide but with noise reduction set at 20-1-20.
This is the same clip using 2-pass VBR with an average bit rate of 7000, again with noise reduction.
My question is this: Does this level of blurring seem normal to you? If not what can I do to remedy this (filters, different encoder, etc...)?
Thanks.
As far as my eyes can tell, you have the same blurring in the original AVI file. I don't use MJPEG for capturing so I don't know if this is normal or not.
The noise reduction filters soften the picture, so if that's what you mean by "less detail", it's normal. You can apply some sharpening if it bothers you but you won't notice it on a normal TV set.
You do seem to be loosing some contrast in the conversion though so you can try playing with the "basic color correction" filter in TMPGEnc. -
Interlaced video will often give viewers that "sharpened edge" look, as opposed to deinterlaced video where it blends the fields together and again noise reduction results in a bit of smooth. However, from seeing your sample videos, your video looks to be excellent quality. Once you put this to DVD and watch it on your TV, you won't let it bother you so much. Video looks better on a TV than it does on a PC screen.
You can use VirtualDub's sharpening filter but I don't recommend it as putting it up really high tends to make the video look "scratchy"...if you can visualize that. Too high and you get speckles in the video. Don't worry about that tad bit of detail loss, you're fine.
LFE audio samples, are there any samples to download and try
By wetduck in forum Newbie / General discussionsReplies: 0Last Post: 14th Mar 2011, 10:17 -
Blurring and overlapping hard subtitles
By jairovital in forum SubtitleReplies: 8Last Post: 26th Oct 2010, 19:37 -
Best music creation software (Dance/Hiphop samples Included)
By Hank Kinsley in forum Off topicReplies: 0Last Post: 30th Oct 2009, 23:50 -
Blurring/Muting.
By silmarallion in forum EditingReplies: 1Last Post: 24th Nov 2008, 11:31 -
Blurring on DVD-rip
By madmillington in forum DVD RippingReplies: 8Last Post: 11th Apr 2008, 18:57
