Results 1 to 11 of 11
    Jun 2004
    Misissauga Ontario
    Is there anyway to delete a menu (or even a certain picture) from a dvd using dvd shrink before backing it up?
    canada
    Try menuedit.
    Jun 2004
    Misissauga Ontario
    i tried menu edit, but it only opens vob files. i want one that just opens the dvd or the dvd image.
    Jun 2004
    Misissauga Ontario
    cant i just use dvd shrink?
  5. Member stackner's Avatar
    Mar 2004
    Digital World, Australia
    use dvdremake. i use it to do the same thing. take a little getting use to but is good.
    Jun 2004
    Misissauga Ontario
    MAN, I gotta buy it???? the free one doesnt let you export.....so there is no point.
  7. Member stackner's Avatar
    Mar 2004
    i strongly belive in not buying stuff if i don't need to for my backups but have a look at what it will cost you. pennys.
  8. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    I wouldn't rush into buying DVDRemake just yet as you look like you already have the tools to do it . You do sometimes have to buy software as people can't program for free can they?, so don't act shocked if someone ever mentions you have to buy something . As for this 'freeware' malarky with software I have seen, I have one question. If everything was 'free' in the world on a larger scale then how would we all survive? For starters nobody would bother working so nothing would ever be produced, so what's the difference with software and people expecting it to be 'free' or no wanting to pay for stuff?
    enough ranting anyway but I'm still not sure what you are trying to do but try using the 'Still Image' feature in DVDShrink and select a black png or jpg to get rid of the menu . The only downside it that it will playback for the same amount of time unless you manually change it or press the skip button on the remote
    are you trying to delete or replace the image in the menu? I know it's been suggested but either way if you have Menuedit (did you pay for that?) then you should be able to delete it by using a blank.VOB (normally 8 or 10kb). If you want to replace it with an image (if it doesn't have buttons) then it can be done by creating a VOB from the image using DVDShrink
    Jun 2004
    Misissauga Ontario
    im not saying that things with a price are bad, im just saying things with a price that are on the internet and not in stores are bad. I have bought Adobe CS upgrade for 233 Canadian. Just last week I bought Nero 6 Ultra Edition for 113 $ CAD. its the internet resourses I dont trust.
    How?
  10. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    as long as you put enough research into buying something of the internet then there is less chance of being disappointed
    I can't believe people are still using links from wherever to buy DVDStripper which has now been free for over 6 months . It just shows how little research people sometimes put into things. Google is your friend as they would soon see that's it free
    anyway back to creating a VOB
    assuming you have your image which should be the right size (720x480 or 720x576) open a DVD with DVDShrink that is the same PAL or NTSC format
    click reauthor and then drag a title across
    now choose to replace it with an image and browse to your image
    click start/end and it should be 12 or 15 frames if it's a 1MB blank
    just crop it to as small as you can get it
    export it and then you have your new VOB to replace with whatever tool you use
    Jun 2004
    Misissauga Ontario
    THanks Mack. Now your talking my language.
