Hi, my hp dvd wirter that came with the pc, doesn't work anymore, so I bought a new one, an external lite on dvd+-rw, and all of the dvds I backup with the new drive don't play on my lapton, an Ibook, I didn't have any problems with the hp writer, the laptop played those, and I'm using the same program, media and everything, why does the laptop doesn't play the dvds I burn with the lite on and it played fine the ones burned with the hp, again, I used the same disks, everytime I insert the dvd the laptop just freezes and I have to manually eject the disc, and then reboot, what's wrong???????
I am assuming you have tried the discs in another DVD player besides the computer they were burned on to rule out that the discs are not recorded properly? If they play properly, try a different disc brand, just to see if that makes any difference.
yes, I have tried them on different dvd player, and they play fine, don't lpay on the ibook only, but it's strange, I used the same media, and with the hp writer they played on the laptop but not when I burn them with the lite on
The only thing I can come up with is to compare the discs that don't play to the ones that do. This site has a few useful tools:http://www.cdspeed2000.com/go.php3?link=download.html
Or hopefully someone else here can figure it out. Good luck.
Toshiba Sat. A200-AH6 laptop DVD drive cannot read DVD DL discs
By MeekloBraca in forum DVD & Blu-ray WritersReplies: 11Last Post: 9th Dec 2009, 03:27 -
Datawrite disc wont read on pc and laptop
By lb77 in forum DVD RippingReplies: 3Last Post: 11th Nov 2009, 10:20 -
DVDs work in desktop PC but not in laptop - previously worked in laptop
By Brent Jewell in forum Newbie / General discussionsReplies: 3Last Post: 6th Nov 2008, 20:40 -
Disk Read Error on My Laptop
By The Monkees in forum ComputerReplies: 6Last Post: 25th May 2008, 23:35 -
MTR can't read DVD... READ ERROR: Can't Open IFO.
By strathq in forum MacReplies: 16Last Post: 17th Jun 2007, 00:04
