Here's the problem: A friend of mine has several MPEG's he burned to a DVD-R. Just burned it like data, not authoring or anything. Not surprisingly, this doesn't work on my DVD-player(Pioneer DV-360), although it works on his (Yamaha Something-or-other) thanks to some fancy built in menus.
So, i come over, try to properly author a dvd. Problem: The files have a bitrate consistent with (S)VCD's and in order to burn them they have to be increased in size, from around .8 GB to around 3 GB. This of course yeilds a little problem with filesizes.
The question: Can I make a DVD, playable on a run-of-the-mill DVD player (That supports (S)VCD of course) without increasing the bitrates? Sort of like a VCD, only DVD-sized. If so, could you tell me what program would be suitable for this, or a guide that explains how to do it?
Sorry if this is already answered somewhere, but this is a huge site.
Convert AND Combine Multiple VCD DAT files to Single Divx/Xvid file
By GrayStrickland in forum Video ConversionReplies: 4Last Post: 17th Aug 2012, 13:23 -
Single 2+ hour DVD file ripping to individual XviD files
By perceptionist in forum DVD RippingReplies: 2Last Post: 16th Mar 2010, 04:40 -
Multiple VCD to single DVD
By Ryan Kelly in forum MacReplies: 7Last Post: 5th Apr 2009, 12:15 -
Easiest way to convert episodes from a dvd to single episode files?
By Pj10 in forum Newbie / General discussionsReplies: 6Last Post: 21st Dec 2007, 22:42 -
Total Video Converter split my DVD into 9 single files
By topek in forum DVD RippingReplies: 2Last Post: 9th Sep 2007, 11:42
