Big problems with my Dvd burner. I've had to format & reinstall everything about 2 weeks ago. I hadn't used my burner for anything until now and I am having some trouble with it.
Pioneer DVD-RW DVR 106D
It will not recognize any discs in the drive!
Not even a retail disc, nothing!!!
Can anyone here help me out with this?
i'd suggest you check your BIOS to make sure the drive is being recognized. if it is check device manager to see if it's listed. make sure you set the drive to DMA mode.
i suggest updating the firmware... if this is happening only since u formated ur computer, then it could be a bad OS install... it happens. try re-formatting it.
I have no clue how to update the firmware, I've tried the forums over at http://www.firmware.fr.st/
but only response I got was "read the faq"
Which really doesn't help much -
this is the latest firmware for ur drive... http://www.pioneerelectronics.com/pio/pe/images/portal/cit_3424/73813268DVRA06_FW108.exe
i have the same drive, just run it. easy, but i think ur prob is more to do with the OS
How to replace new DVD burner and HDD for pioneer DVR-550H?
By voa in forum DVD & Blu-ray RecordersReplies: 5Last Post: 20th Mar 2012, 09:35 -
Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
By psymaster in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2009, 20:48 -
By psymaster in forum Latest Video NewsReplies: 1Last Post: 31st Oct 2009, 18:26 -
Pioneer DVR-543HS , is my DVD burner toast?
By stew182 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 27th Sep 2008, 13:57 -
Pioneer 106D & Maxell 8x DVD-R
By piano632 in forum DVD & Blu-ray WritersReplies: 1Last Post: 22nd Jun 2007, 18:38
