Hi,
After using TMPGenc for a while, I finally got to the point to use CCE 2.67. However, I can't get it to work properly.
When I use TMPGenc to convert a 1hr15 min. movie to SVCD (using DVD2SVCD v1.2.2) on a single disc it does so without problems.
When I change the settings to CCE everything seems fine....untill the CCE screen pops up. Instead of VBR one pass....the screen says MP CBR 6000 kbps (?!?! seems to me that this bitrate is waaaay to high) and does 3 passes. Instead of doing the whole movie....it only took 29 minutes of it.
I'm puzzled. I tried a couple of things but nothing worked in the end. Don't wanna go back to TMPGenc either....![]()
Anybody there who could give me a clue what to do??
Cheers
Richard
Forgot to post the logfile:
WNASPI32.DLL 4.71.2.0
- 8-8-2004 18:38:06
- DVD to SVCD Conversion
- DVD2SVCD ver. 1.2.2 build 1
Initializing
- G:\Final Movies\Nog te branden\JB1\Jungle book 1\VTS_01_0.BUP
- G:\Final Movies\Nog te branden\JB1\Jungle book 1\VTS_01_1.vob
- G:\Final Movies\Nog te branden\JB1\Jungle book 1\VTS_01_2.vob
- G:\Final Movies\Nog te branden\JB1\Jungle book 1\VTS_01_3.vob
- G:\Final Movies\Nog te branden\JB1\Jungle book 1\VTS_01_4.vob
Initializing finished.
- 8-8-2004 18:38:08
- Free on drive G: 24273.66 mb
- vStrip
Preparing vobfiles to be ripped:
Saving the vStrip filelist:
- G:\Final Movies\Nog te branden\JB1\vStrip.lst
Executing vStrip. Commandline:
"C:\Program Files\VideoTools\DVD2SVCD\vStrip\vStrip.exe" @"G:\Final Movies\Nog te branden\JB1\vStrip.lst" -i"G:\Final Movies\Nog te branden\JB1\VTS_01_0.BUP" -j1 -$1024 -p0 -o"G:\Final Movies\Nog te branden\JB1\VTS_01.vob"
- 8-8-2004 18:44:44
- DVD2AVI
Creating DVD2AVI INI file:
- C:\Program Files\VideoTools\DVD2SVCD\DVD2AVI\DVD2AVI.INI
Variable settings:
iDCT_Algorithm: 32-bit SSE MMX
Executing DVD2AVI.
Executing DVD2AVI. Commandline:
"C:\Program Files\VideoTools\DVD2SVCD\DVD2AVI\DVD2AVI.exe" -CS=2 -YR=1 -OM=0 -EXIT -OF=[G:\Final Movies\Nog te branden\JB1\DVD2AVI_Project_file] -IF=[G:\Final Movies\Nog te branden\JB1\VTS_01_1.vob,G:\Final Movies\Nog te branden\JB1\VTS_01_2.vob]
Framerate: 25000
DVD2AVI processing done.
- 8-8-2004 18:46:05
- Free on drive G: 23812.11 mb
- AUDIO Extraction
Found AC3 stream id: 0x83
Filename: G:\Final Movies\Nog te branden\JB1\Extracted_audio_1.ac3
Audio1 delay: 0 ms
Audio extraction finished.
Encoding Audio. Filename: G:\Final Movies\Nog te branden\JB1\Extracted_audio_1.ac3
Executing BeSweet. Commandline:
"C:\Program Files\VideoTools\DVD2SVCD\BeSweet\BeSweet.exe" -core( -input "G:\Final Movies\Nog te branden\JB1\Extracted_audio_1.ac3" -output "G:\FINALM~1\NOGTEB~1\JB1\Encoded_audio_1.mp2" -logfile "G:\FINALM~1\NOGTEB~1\JB1\Encoded_audio_1.log" ) -azid( -L -3db -l 0db -c normal -s surround -g max ) -shibatch( --rate 44100 ) -2lame( -e -b 224 -m s )
Audio conversion of G:\Final Movies\Nog te branden\JB1\Extracted_audio_1.ac3 finished.
Audio conversion finished.
- 8-8-2004 18:52:43
- Free on drive G: 23764.88 mb
- Video Encoding using Cinema Craft
Executing Cinema Craft Encoder.
StreamSectors: 771186864
AudioSectors: 50444744
VideoPAPO: 11164680
ScanOffsetBytes: 53176
SeqAligningBytes: 3379605
DVDBytes: 0
VideoEndHeader: 4
SubtitleSectors: 0
EmptySectors: 238.00
PictureSectors: 1.00
PureMPEGStream: 706144655.60
Seconds: 1777.52
CalcMPEGStream: 706144655.60
Frames: 44313
CDSize: 740.00
Number of CDs: 1
Cut point 735.00
Variable Settings:
Frames: 44313
Anti Noise Filter: Off
Passes: 2
Image Quality: 17
VAF file creation: On
Video Encoding Mode: One Pass VBR
Q. Factor: 1
Min. bitrate: 300
Max. bitrate: 2230
Aspect Ratio: 16:9 (borders added, encoded as 4:3)
---AVS Begin---
LoadPlugin("C:\PROGRA~1\VIDEOT~1\DVD2SVCD\AVISYN~1 .5PL\Mpeg2dec\MPEG2D~1.DLL")
MPEG2Source("G:\FINALM~1\NOGTEB~1\JB1\DVD2AV~1.D2V ")
BicubicResize(480,432,0.0,0.6)
AddBorders(0,72,0,72)
Import("G:\Final Movies\Nog te branden\JB1\ResampleAudio.avs")
ResampleAudio(44100)
ConvertToYUY2()
----AVS End----
Program Handle not found, terminating program.
CCE Max Speed: 0.000
Video Encoding finished.
- 8-8-2004 20:29:47
- Free on drive G: 22487.36 mb
- Converting Pictures from ES to PS
Saving bbMPEG settings: C:\Program Files\VideoTools\DVD2SVCD\bbMPEG\default.ini
- 8-8-2004 20:29:50
- 8-8-2004 20:29:53
- 8-8-2004 20:29:56
- Multiplexing and cutting
Offset in Seconds: 2
Executing bbMPEG.
Variable Settings:
Movie offset: 2 seconds
Cut point: 735 mb
Executing RunbbMPEG. Commandline:
"C:\Program Files\VideoTools\DVD2SVCD\bbMPEG\RunbbMPEG.exe" "G:\Final Movies\Nog te branden\JB1\bbMPEG_Muxed_File.mpg"
Multiplexing and cutting finished.
- 8-8-2004 20:33:37
- Free on drive G: 21753.08 mb
- Determining length of audio
Analyzing: G:\Final Movies\Nog te branden\JB1\bbMPEG_Muxed_File00.mpg
971.755 seconds G:\Final Movies\Nog te branden\JB1\bbMPEG_Muxed_File00.mpg
Analyzing finished.
- 8-8-2004 20:34:14
- Free on drive G: 21753.07 mb
- Creating CD-Images using VCDXBuild
- No. of chapters to create: 17
CD image #1: CD_Image_File_CD1.bin
Executing VCDXBuild. Commandline:
"C:\Program Files\VideoTools\DVD2SVCD\VCDImager\VCDXBuild.exe" --verbose --cue-file="G:\FINALM~1\NOGTEB~1\JB1\CD_Image_File_CD1.c ue" --bin-file="G:\FINALM~1\NOGTEB~1\JB1\CD_Image_File_CD1.b in" "G:\FINALM~1\NOGTEB~1\JB1\VCDXBU~1.XML"
Image creation finished.
- 8-8-2004 20:36:59
- Free on drive G: 21008.59 mb
- Conversion done!
Capture AT&T (ATT) Uverse video signal & AT&T Uverse DVR programs
By bluehan2010 in forum Capturing and VCRReplies: 1Last Post: 23rd Apr 2010, 10:40 -
DVD Rebuilder Pro & CCE in Multipass VBR mode
By devnulllore in forum Newbie / General discussionsReplies: 12Last Post: 30th Jul 2007, 09:04
