I have tried to follow the directions given and guide after guide to get DVD-RB to work. When I use dvddecrypter it rips the dvd fine and then I go into DVD-RB and click on prepare where it starts working but then a html box comes up and it says:
Warning! The input directory is already small enough to fit on a DVD-5. No compression is necessary. Continue anyway?
Then it starts and says it is going through phases of preparation. Scanning and writing a .d2v file. Then a html box comes up saying:
Run time error '9': Subscript out of range.
When I click on OK it closes the whole program.
So are there any ideas out there?
This means YOU DO NOT NEED TO DO ANY ENCODING as your source is already small enough to fit a DVD+-R.Warning! The input directory is already small enough to fit on a DVD-5. No compression is necessary. Continue anyway?
Please check your source: Go to the source directory (where you put your ripped files with Windows Explorer, right click the VIDEO_TS directory and check Preferences. If the size is lower than 4.37 GB( or 4642 MB) the film can just be burned without ant compression.
PabloNewbie to DVD backup -
pg55555
So what do I do once that says that...I am not going to be able to use CCE SP? I don't get a message until it goes through all that...BUT, I do want to be able to use the CCE SP to get the best picture on my burn...I have Nero6 Ultra. -
As pg55555 says - you can simply copy this to a new DVD WITHOUT having to go through CCE. You will have identical quality to the original because you won't be changing anything.
This is as simple as it gets.
DVD in BD Rebuilder!!!
By fjmr in forum Blu-ray RippingReplies: 3Last Post: 18th Aug 2009, 10:22 -
dvd rebuilder
By dvd1304 in forum Newbie / General discussionsReplies: 2Last Post: 20th Jul 2009, 12:31 -
DVD Players no longer work on tv?? Any ideas?
By -mm- in forum DVD & Blu-ray PlayersReplies: 4Last Post: 15th Nov 2008, 19:13 -
Any good ideas for an engagement DVD?
By Rudyard in forum Newbie / General discussionsReplies: 2Last Post: 3rd Dec 2007, 21:03 -
Is there a resource for good looking DVD Menu ideas
By PlayWithFire in forum Authoring (DVD)Replies: 15Last Post: 31st Jul 2007, 15:00
