Hello all again ill get raight to the point.... I have a couple .rm files ive been trying to convert to .avi with no luck, ive been using a program called tinra and when the file is done converting there is no video stream just audio so iwas wondering if anyone else out there has run into this problem and knows how to fix it or can recomend something better to convert . rm files i would be Very Greatful Thanks a bunch!
Thread: RM HELP?
EO video tends to be slow at times. I use TMPGENC with the Real Alternative codec, and it tends to be faster than EO Video. I think this only works with an older version of TMPGENC though.
