Im new to conversion so please be gentle..Im testing Procoder 2 (after doing some reading)to see if it will fit my needs. Im converting vhs to dvd. im using advc 50 to dv then I would like to use procoder to resize to 352 X 480.I cant seem to find this option. Is it possible. How about 2.0 AC3? one more question...can you frameserve with one of the capture programs like scenalyzer or windv strait to an encoder? thanx
I meant using procoder to resize to 352 X 480 (half D1)and encode to MPEG2(vob)
In the target area, select "mpeg file".
On the next screen, change the width and height to whatever you want, as long as it's legal for the type of file you're creating.....ie: 352x480 for mpeg 2, etc.
By the way, I do the same thing you are.
ADVC to capture VHS as DV file using Scenalizer, and Procoder to encode the MPEG-2 file.
Then on to TMPGenc DVD Author to finish the job.
Very good results. -
Kool_aid Sorry to bother you but you have been a big help and I need a little more. What settings do you use for your bitrate? What quality? Can you just tell me all your settings? Also do you frameserve from scenalyzer to procoder? Ive been trying but no luck any and all help is greatly appreciated…..John(aka mayday56)
No, I don't frameserve.
I capture as Canopus DV Codec, with Scenalyzer.
Load that file into Procoder, and convert.
I always use Maser Quality 2 pass VBR @ 6000
If the source is VHS then I use half D1.
Everything else I use full D1
Then, load those two files (video + audio) into TMPGEnc DVD Author, and have it convert the audio to AC3, (to save room) and make the menus, etc.
I always convert the finished folders to an ISO file, and mount it to a virtual drive to check everything, before doing the DVD burn with DVD Decrypter.
If I have to shrink it a little, DVD Shrink will make the ISO then.
If the size is ok, then I use ImgTool Classic 0.91.3 to make the ISO.
avi to dvd after scenalyzer capture
By robroth in forum Authoring (DVD)Replies: 7Last Post: 9th Jan 2012, 17:23 -
Scenalyzer, optical scene detection
By BTB554 in forum Capturing and VCRReplies: 2Last Post: 15th Jun 2011, 23:48 -
How to frameserve from virtualdub to ProCoder2 ?!?!
By simps in forum Video ConversionReplies: 22Last Post: 14th Feb 2010, 12:16 -
Scenalyzer and Vista
By bobogs in forum Capturing and VCRReplies: 3Last Post: 16th Jul 2007, 21:03 -
Scenalyzer Live 4.0
By Jone.T in forum EditingReplies: 1Last Post: 7th May 2007, 08:38
