Hello i need some help i am learning how to put mpeg2 files on dvd. I need to put more than two hours on one DVD but the software that i am using only lets me do two hours, is there a way to do more. I am using pinnacle studio 8.
Quit using Studio 8. It's the only software I ever tried that gives you absolutely no control over that.
TMPGEnd DVD Author, DVD Lab, Power Director/Power Producer and many others will let you create DVD files over 2 hours (and you can then use DVD Shrink if the files are too big for the disk). All 3 programs I mentioned have free trials. -
What do you use to edit. My main thing is that i edit out commercials out of my tv shows and then try to put them on dvd. ????
The cool thing that i found is that i can do it all with studio 8 plus it came with my video card so i thought that i would try it. So i am open to suggestions.
Thanks -
I use TMPGEnc DVD Author and Cyberlink's Power Producer 2 Gold. I used Studio 8 for almost 6 months before I figured out it was one of the worst choices as far as speed, stability and control over some aspects.
If you're capturing to avi with the Studio card then Power Producer 2 Gold would be the better choice (of the 2 I mentioned). It's much, much faster than Studio and it will work with the Studio captured avi files.
TMPGEnc DVD Author will not accept the captured files. -
Luckly i don't have to worry about bring in an AVI to Mpeg. I have a replayTV and i use DVarchive to extract the mpeg2 fromat off the harddrive,edit it, then author and burn. I agree that studio takes forever to a task. What is the quality of video using Tmpeg???
Avid Studio vs. Sony Vegas Pro/Studio
By HoosierGuy in forum EditingReplies: 12Last Post: 8th Dec 2011, 20:06 -
Is Studio 11 any better than 8 or 9?
By rcguy1 in forum Newbie / General discussionsReplies: 2Last Post: 11th Apr 2008, 15:02 -
Sony Vegas Movie Studio/DVD Architect Studio
By DJL82 in forum EditingReplies: 8Last Post: 1st Feb 2008, 15:14 -
PINNACLE STUDIO 11 vs. SONY VEGAS MOVIE STUDIO 8
By coody in forum Capturing and VCRReplies: 4Last Post: 26th Nov 2007, 18:53 -
Studio DC10 Plus analog Card, XP and Studio 10 capture split in half
By jackylhome in forum Capturing and VCRReplies: 0Last Post: 22nd May 2007, 22:48
