I am trying to something which should be fairy simple, but it's turning into a bit of a nightmare-
Trying to capture mini DV tape contents, edit them, and burn them on a DVD.
Here's the set up
Windows XP Home, fully updated (Laptop)
Firewire card thru PC slot (compatible with IEEE1394-1995, P1394a and OHCI standards)
Sony TRV Camcorder DCR TRV15E (mini DV)
Windows Movie Maker
When I have WMM Capture the video, it says Device not Found.
When I trobleshoot the firewire adapter with the camcoder plugged in it say 'Device Cannot Start'. When I trouble shhot the set up, its says to download drivers, but none are available. So that does not help me.
When I trouble shoot the Firewire card without a cable plug in, it says it's fine.
Been to Sony website, but they only have device drivers for USB connections. All the postings seem to suggest I do not need a driver for the Sony with a Firewire.
I tested the set-up upon my old MAC. It works fine with iMovies, but I dont have any burners on that system. So the camera and cable are OK.
I realise WMM does not have the ability to burn to DVD, so was just going to use this program to edit, and sort the other bit out later.
So, Where does the problem lie? The Firewire adaptor or WMM I guess.
Any help towards drivers or better peices of software to help achive what I want to do would be really apreciated.
Thanks a lot.
It's one of two things most likely:
1) That freaking Sony camera. They are LOUSEY as far as connectivity goes. They have GREAT connectivity to Sony Vaio computers though.
2) Try this official Windows fix:
http://support.microsoft.com/?kbid=810032
Capture progressive mini-dv tape on interlaced mini-dv cam ?
By alip in forum Capturing and VCRReplies: 4Last Post: 8th Feb 2011, 18:27 -
Sony DCR-TRV9 mini DV cam, lots of dropouts, lose sync in iMovie
By lipwak in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 28th Oct 2010, 12:20 -
New Canon Mini-DV Camcorder, Problems capturing
By captain_tinker in forum Capturing and VCRReplies: 8Last Post: 18th Feb 2009, 00:36 -
mini dv cam / min focal distance?
By kr236rk in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 27th Jul 2008, 10:57 -
How should I know my mini dv cam is shooting a true 16:9
By joy in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 5th Oct 2007, 13:34
