  1. i cant framserve with virtualdub properly, ive installed the file handler. I can framserve only 1 out of my 4 movies, when i open the VDR file in TMPGEnc, 3 out of the 4 movies show up stuffed! only 1 framserves properly! the three movies in 23.97FPS give a distorted image that is tripled across 1 frame and is in grey colour. WHY IS THIS HAPPENING? I HAVE TRIED EVERYTHING TO FIX THE STUPID THING.
    For a glimpse of the image goto ftp://144.132.191.157/image1.jpg
    Why does this happen? ive tried altering the priority settings for everything, and it still happens! i know my PC can framserve, because 1 out of the 4 movies WORKS! WHAT DO I DO!!!!!!!!!!!!!!!!!
  2. Did you install properly?
    - Did you use Auxsetup.exe?
    - Did you experiment with the the AVI file proxy support?
    (VirtualDub\aviproxy\proxyon.reg - proxyoff.reg)
  3. I've only frameserve one movie at a time. Are you batch frameserving??
    Maybe u have to proxyoff/on between movies, just a quess.
  4. Install a copy of virtualdub for each movie your frameserving. Make sure there in different directories
  5. I got the stupiud thing working fine, how? i installed virtuadub v1.4 because 1.47 is a pain in the ass
